carb conversion questions(1966tbird help me)
on
Put a stat in it man.. it's taking forever to go closed loop without one so the computer isn't learning what the motor needs. E cam will not idle like stock but it should be relatively stable if everything is working right. Are you using 19lb injectors or something bigger?
I bet if you had a datalogger you would see what's up, I'm having a lot of fun with my TweecerRT trying things.
yea conanski i know that,(not tryin to be a smartass,lol)i just havent had time,the more spark thing on my tuner is that u can add more spark at wot,and alot of other things.im really leaning towards getting a moates quaterhorse,tweecer is kinda high in price for me,and the moates stuff has alot of options like chip burners and stuff.i was messing with my tuner the other day and changed the maf table to one from a 95w4ho eec,and it idled alot better but i messed somthin up in the tune,lol and it wouldnt hardly start.the maf table on the a9p and a9l is high at idle like around 13 at idle and the 95s was like 8,if u know wut im talking about,lol.i dont have alaptop yet so the datalogging stuff will have to wait till after christmas.but yea conanski the tuning thing is kinda fun.with my tuner u can change all kinds of stuff on the 94-95 eec,all the shift points and all that.
and right now im using stock 19 lbs injectors,i have a question about injectors,the ones im using were in the speed density system in the truck,are injectors different from mass air set ups?i have the ones from the car i got the other stuff from.and as far as the idle i have heard alot of stuff with ecams and bcams and it didnt idle nuthing like this,it has alot of torque,it will spin "the" tire like hell from a stop,it has good throttle response and all but just doesnt idle very good,it acts like a carb thats loading up real bad.
hey conanski could u give me some help on tuning if u know some good stuff about it.
conanski on your wideband,well on ur efi set up how many 02s do u need,one or two,im wanting to get a wideband for tuning but would it work good just in one bank?could u tune with that?i know u can make the wideband feed the eec like the narrow band.does the wideband read correctly at idle,someone told me they arent good except at wot.
on
No difference in those injectors, the orange top 19lbers are all the same. I was messin with the timing curves today myself, pretty cool that you can highlight a whole block in the base timing table for example and just add 5 degrees across the board.
My truck has been running a single O2 sensor in passenger exhaust header right up until today, and it runs fine like that. I have been meaning to modify my truck for dual sensors for some time and finally got around to it, just wanted to see if it makes any difference. And no it really doesn't make any difference, fuel trims are pretty much identical on both banks with dual sensors just like they are when only using one. I'm thinking it would only matter if there is a bad injector. I am currently using the narrowband output from my wideband to drive the second input on the EEC and it works as expected. These sensors have to calibrated in free air to produce accurate results too, if done in the exhaust pipe the readings will be way off.
wut eec are u running?u know how the a9p and a9l need two sensors,i have both hooked up to my stock o2sensor,so im hoping when i put one in each pipe it will run a lil better.my tuner isnt as advanced as urs is,on mine is set up like this
A9P
CHECKSUM_BASE_ADDRESS 8192 # Set to 0 to clear Error code 15
WOT_VOLTAGE 2.71 # WOT TPS breakpoint (V)
PART_THROTTLE_SPARK_ADDER 0 # Part Throttle spark adder (Deg BTDC)
WOT_SPARK_ADDER 0 # WOT spark adder (Deg BTDC)
TIP_IN_RETARD 0 # Tip-in spark retard (Deg BTDC)
LOW_DWELL 0.500008 # Max low speed dwell (off time in ms)
HIGH_DWELL 0.2 # Max high speed dwell (off time in ms)
WOT_ADVANCE_VS_RPM # WOT spark Advance vs RPM
( 16383.8, 26 ) ( 5000, 26 ) ( 3500, 22 )
( 2600, 23 ) ( 2250, 22 ) ( 1600, 18 )
( 0, 18 ) ( 0, 18 )
WOT_ADVANCE_VS_ECT #
( 254, -4 ) ( 246, -4 ) ( 236, -2 )
( 200, 0 ) ( 120, 0 ) ( 86, 3 )
( -256, 3 )
WOT_ADVANCE_VS_ACT #
( 254, -6 ) ( 240, -6 ) ( 150, 0 )
( -256, 0 ) ( -256, 0 ) ( -256, 0 )
PT_ADVANCE_VS_ACT #
( 254, -2 ) ( 190, -2 ) ( 160, 0 )
WOT_ADVANCE_VS_BP #
( 31.875, 0 ) ( 27.75, 0 ) ( 26.5, 4 )
( 23.5, 4 ) ( 0, 12 )
ADVANCE_RATE_VS_RPM #
( 8160, 1 ) ( 4000, 1 ) ( 3008, 1.5 )
( 992, 2 ) ( 0, 2 ) ( 0, 2 )
MIN_LOW_SPEED_DWELL #
( 4095.94, 0.00279999 ) ( 15, 0.00279999 ) ( 14, 0.00300027 )
( 12, 0.00399972 ) ( 10, 0.00449944 ) ( 0, 0.00449944 )
MIN_HIGH_SPEED_DWELL #
( 4095.94, 0.00300027 ) ( 15, 0.00300027 ) ( 13, 0.00334931 )
( 12, 0.00370026 ) ( 10, 0.00499917 ) ( 0, 0.00499917 )
BASE_SPARK_TABLE # Base Spark Table (Deg BTDC)(RPM vs Load)
28 28 28 30 30 30 30 30 30 30
28 28 33 36 36 37 38 38 38 38
25 26 30 33 35 36 38 40 39 39
15 15 22 28 29 30 33 34 34 35
10 10 11 14 19 20 27 29 29 29
7 7 8 12 15 19 22 25 26 26
7 7 8 10 12 15 20 22 23 23
SEALEVEL_LOM_SPARK_TABLE # Spark Table (Deg BTDC)(RPM vs Load)
28 28 28 31 33 34 34 34 34 34
25 26 31 34 34 34 36 38 38 38
20 21 25 28.5 31 32 33 34 33 35
15 16 18 21 21.5 22 27 29 30 29
12 13 14 15 16.5 17.5 22 25.5 26 26
6.5 8 9 10 12 14 18 22 23 23
6.5 6.5 9 10 12 14 18 22 23 23
ALTITUDE_LOM_SPARK_TABLE # Altitude base spark table.
28 28 28 28 28 28 28 28 28 28
7 7 8 10 12 15 19 21 22 22
SPARK_TABLE_RPM_SCALING #
( 16383.8, 9 ) ( 4000, 9 ) ( 3000, 8 )
( 1500, 5 ) ( 700, 1 ) ( 625, 0 )
( 0, 0 )
SPARK_TABLE_LOAD_SCALING #
( 1.99997, 7 ) ( 0.75, 7 ) ( 0.600006, 6 )
( 0.100006, 1 ) ( 0.0499878, 0 ) ( 0, 0 )
( 0, 0 )
OPEN_LOOP_FUEL_MULTIPLIER 0.996094 # Global open loop fuel multiplier
ENGINE_DISPLACEMENT 301.083 # Engine Displacement
MAF_VOLTAGE 4.78523 # Max MAF voltage
MAF_FUNCTION # Mass Air Transfer Function
( 15.9998, 835.509 ) ( 4.76807, 835.509 ) ( 4.44312, 695.465 )
( 4.177, 595.977 ) ( 3.88599, 499.658 ) ( 3.54395, 399.219 )
( 3.35498, 347.574 ) ( 3.14893, 295.612 ) ( 2.90991, 243.334 )
( 2.69409, 201.828 ) ( 2.58203, 182.5 ) ( 2.44995, 161.272 )
( 2.31592, 142.261 ) ( 2.15405, 120.083 ) ( 1.98901, 100.122 )
( 1.88989, 90.2996 ) ( 1.80298, 82.3786 ) ( 1.69092, 72.8734 )
( 1.57397, 62.4176 ) ( 1.46802, 54.1798 ) ( 1.32104, 44.6745 )
( 1.18188, 36.7535 ) ( 1.09106, 32.6346 ) ( 0.884033, 23.7631 )
( 0.75, 18.6936 ) ( 0.571045, 13.6242 ) ( 0, 13.6242 )
( 0, 13.6242 ) ( 0, 13.6242 ) ( 0, 13.6242 )
BASE_FUEL_TABLE # Base Fuel Table (A/F ratio)(Load vs ECT)
15.3262 15.3262 15.3262 15.0975 14.9831 14.64 14.64 13.9537 13.9537 13.9537
14.64 14.64 14.64 14.64 14.64 14.64 14.64 13.9537 13.9537 13.1531
12.9244 13.1531 13.4962 13.6106 13.6106 13.6106 13.6106 13.9537 13.9537 13.1531
12.4669 13.1531 13.2675 13.6106 13.9537 13.9537 13.9537 14.5256 14.0681 13.2675
11.6662 12.6956 13.1531 13.0387 13.4962 13.6106 13.9537 14.2969 14.2969 14.2969
11.0944 12.0094 12.6956 12.4669 12.6956 13.0387 13.4962 14.2969 14.2969 14.2969
10.5225 11.4375 12.0094 12.4669 12.6956 13.0387 13.1531 12.6956 12.6956 12.4669
10.065 10.6369 11.4375 11.4375 11.6662 12.0094 12.3525 12.3525 12.3525 12.3525
STARTUP_FUEL_TABLE # Subtract corresponding cell values from BASE_FUEL_TABLE for startup/warmup enrichment
3.08812 2.97375 3.08812 1.71562 1.71562 1.71562 1.71562 1.25812 1.71562 2.97375
2.51625 2.63062 2.63062 1.71562 1.71562 1.71562 1.71562 1.48687 1.71562 2.97375
2.51625 2.63062 2.2875 1.71562 1.71562 1.71562 1.71562 1.3725 1.71562 2.63062
2.05875 2.2875 2.17312 1.71562 1.71562 1.71562 1.71562 1.14375 1.71562 2.17312
1.48687 1.71562 1.60125 1.3725 1.14375 1.14375 1.14375 1.02937 1.3725 1.71562
1.14375 1.3725 1.3725 0.571875 0.571875 0.571875 0.571875 0.4575 0.800625 1.48687
0.915 0.915 0.915 0.4575 0.4575 0.4575 0.4575 0.22875 0.4575 0.800625
0 0 0 0 0 0 0 0 0 0
FUEL_TABLE_LOAD_SCALING #
( 1.99997, 7 ) ( 0.899994, 7 ) ( 0.700012, 5 )
( 0.399994, 3 ) ( 0.149994, 1 ) ( 0.0750122, 0 )
( 0, 0 )
FUEL_TABLE_ECT_SCALING #
( 254, 9 ) ( 240, 9 ) ( -30, 0 )
WOT_FUEL_MULTIPLIER_VS_RPM # WOT Fuel Multiplier vs RPM
( 16383.8, 0.945312 ) ( 6000, 0.945312 ) ( 4400, 0.953125 )
( 3800, 0.976562 ) ( 3200, 0.945312 ) ( 2400, 0.96875 )
( 1600, 0.90625 ) ( 0, 1 )
OL_FUEL_MULTIPLIER_VS_RPM #
( 16383.8, 1 ) ( 0, 1 ) ( 0, 1 )
( 0, 1 ) ( 0, 1 ) ( 0, 1 )
SEA_LEVEL_LUGGING_OL_FUEL_MULTIPLIER #
( 16383.8, 1 ) ( 1500, 1 ) ( 1200, 1.20312 )
( 750, 1.20312 ) ( 650, 1 ) ( 0, 1 )
ALTITUDE_LUGGING_OL_FUEL_MULTIPLIER #
( 0, 1 ) ( 0, 1 )
OL_FUEL_MULTIPLIER_VS_ACT #
( 254, 1 ) ( 76, 1 ) ( 0, 0.8125 )
( -40, 0.640625 ) ( -256, 0.640625 ) ( -256, 0.640625 )
CRANK_FUEL_PULSEWIDTH_MULTIPLIER_VS_TIME #
( 8191.88, 1 ) ( 0, 1 ) ( 0, 1 )
CRANK_FUEL_PULSEWIDTH_VS_ECT #
( 65534, 0.00199893 ) ( 180, 0.00199893 ) ( 150, 0.0023003 )
( 70, 0.00569924 ) ( 40, 0.010502 ) ( 20, 0.0141489 )
( 0, 0.0218891 ) ( -20, 0.0387617 ) ( -65536, 0.0387617 )
GLOBAL_ACCEL_MULTIPLIER 1 # Global Accel pump multipler
ACCEL_ENRICHMENT_VS_TPS # Accelerator Enrichment Multiplier vs TP voltage
( 4.98047, 0.5 ) ( 2.44141, 0.75 ) ( 0, 1 )
( 0, 1 ) ( 0, 1 )
ACCEL_ENRICHMENT_FUEL_TABLE # Accelerator Enrichment Fuel Table(lb/min)
16 19 22 25 27 31 34 37
5 9 9 9 10 12 15 18
3 4 5.75 6.25 7.25 11 13 14
3 4 5.75 6 4 4 4 4
1 1 1 1 1 1 0 0
0 0 0 0 0 0 0 0
LOW_INJECTOR_SLOPE 26.0995 # Injector slope lbs/hr
HIGH_INJECTOR_SLOPE 19.6416 # Injector size lbs/hr
INJ_DELAY 0 # Global injector delay (crank deg.)
INJECTOR_TIMING_TABLE # Injector timing table
280 280 280 280 280 280 280 280 280 280
332 332 332 332 332 332 332 332 332 332
380 380 380 380 380 380 420 420 464 464
420 420 420 420 420 420 420 464 464 464
INJECTOR_FIRING_ORDER # Injector firing order
1 3 7 2 6 5 4 8
INJECTOR_OFFSET_VS_BATTERY_VOLTAGE #
( 15.9375, 0.90625 ) ( 14, 0.90625 ) ( 13, 1 )
( 12, 1.15625 ) ( 11, 1.40625 ) ( 10, 1.6875 )
( 9, 2.03125 ) ( 8, 2.59375 ) ( 7, 3.53125 )
( 6, 5.53125 ) ( 5.5, 7.5 ) ( 0, 7.5 )
INJECTOR_OUTPUT_PORT # Injector Output Port Table
0 0 0 0 2 2 2 2
FAN_TEMP 220 # Coolant temp for Electric Fan (Deg F)
FAN_ENABLE 0 # Electric Fan control enable(0=no, 1=yes)
CLOSED_THROTTLE_SPARK_ADDER 0 # Closed Throttle spark adder (Deg BTDC)
CLOSED_THROTTLE_OL_FUEL_MULTIPLIER # Closed Throttle Open Loop Fuel Multiplier
DRIVE_IDLE 624 # Drive Idle RPM
NEUTRAL_IDLE 672 # Neutral Idle RPM
DASHPOT_CLIP #
( 16383.8, 0.75 ) ( 5000, 0.75 ) ( 1500, 0.699951 )
( 1200, 0.5 ) ( 0, 0.5 )
DASHPOT_DECREMENT_RATE #
( 15.9998, 0.00708008 ) ( 0.449951, 0.00708008 ) ( 0.199951, 0.00292969 )
( 0, 0.00292969 ) ( 0, 0.00292969 ) ( 0, 0.00292969 )
( 0, 0.00292969 )
PIP 961 # Min PIP period. (PIP = 6250000/maxRPM)
HALF_FUEL_REV_LIMIT_ON 6200 # Turn on half-fuel rev limit
HALF_FUEL_REV_LIMIT_OFF 6100 # Turn off half-fuel rev limit
SECOND_SPEED_LIMITER_ON 127.5 # Turn on 2nd speed limiter (MPH)
SECOND_SPEED_LIMITER_OFF 127.5 # Turn off 2nd speed limiter (MPH)
FIRST_SPEED_LIMITER_ON 127.5 # Turn on 1st speed limiter (MPH)
FIRST_SPEED_LIMITER_OFF 127.5 # Turn off 1st speed limiter (MPH)
NO_FUEL_RPM 6200 # Max RPM (no fuel)
MIN_LOAD_FOR_CLOSED_LOOP 0.00500488 # Minimum load for CL contorl
TIME_AT_HIGH_LOAD_BEFORE_OPEN_LOOP 2 # Time at high load to force OL (sec)
MIN_ECT_FOR_FUEL_SHUTOFF 140 # Min ECT for decel fuel shutoff (Deg F)
MIN_RPM_FOR_FUEL_SHUTOFF 6000 # Min RPM for decel fuel shutoff (Deg F)
MIN_ACT_FOR_ADAPTIVE_CONTROL 100 # Min ACT for Adaptive Control (Deg F)
MAX_ACT_FOR_ADAPTIVE_CONTROL 200 # Max ACT for Adaptive Control (Deg F)
EGR_MULTIPLIER 0.898438 # EGR multiplier
EGR_TYPE 0 # EGR type (0=sonic, 1-PFE, 2=none)
THERMACTOR_PRESENT 1 # Thermactor present (0-no, 1-yes)
EXHAUST_PULSE_DELAY #
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
NUMBER_OF_HEGOS 2 # Number of HEGO's
HEGO_AMPLITUDE #
0.0332031 0.0332031 0.0332031 0.0332031
HEGO_BIAS #
0 0 0 0
0 0 0 0
-0.00878906 0 0.00292969 0
-0.00878906 0 0 0
-0.00878906 0 0 0
0 0 0 0
EMISSION_TABLE_LOAD_SCALING #
EMISSION_TABLE_RPM_SCALING #
( 16383.8, 3 ) ( 1500, 3 ) ( 1000, 1 )
( 700, 0 ) ( 0, 0 ) ( 0, 0 )
( 0, 0 ) ( 0, 0 )
END
A9P
( 0, 18 ) ( 0, 18 )
( -256, 3 )
PT_ADVANCE_VS_ACT #
WOT_ADVANCE_VS_BP #
( 0, 0 )
( 0, 0 )
0 0 0 0 0 0 0 0 0 0
( 0, 0 )
( 0, 1 ) ( 0, 1 )
( 0, 1 ) ( 0, 1 )
5 9 9 9 10 12 15 18
3 4 5.75 6 4 4 4 4
1 1 1 1 1 1 0 0
0 0 0 0 0 0 0 0
1 3 7 2 6 5 4 8
0 0 0 0 2 2 2 2
DASHPOT_CLIP #
( 0, 0.00292969 )
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
10 10 10 10
HEGO_AMPLITUDE #
HEGO_BIAS #
0 0 0 0
0 0 0 0
-0.00878906 0 0 0
-0.00878906 0 0 0
0 0 0 0
( 0, 0 ) ( 0, 0 )
END
i dont know much about how the tweecer works,but mine is pretty simple just cant log with it.but on mine u just go in there and change the numbers to wut u want then download it to the eec,and my tuner u can use a p.c with,it has a power cord that plugs up to the board in the eec,so thats one reason i got it,i have no laptop and it only cost me 100,and i wanted it to turn off the egr and thermactor stuff,and i can use it to control the fan with the ect
heres the maf table from the a9p i have
and heres the one from the 95w4ho
( 15.9998, 932.145 ) ( 5, 932.145 ) ( 4.75, 808.577 )
( 4.5, 697.683 ) ( 4.25, 598.512 ) ( 4, 510.114 )
( 3.80005, 446.745 ) ( 3.6001, 389.397 ) ( 3.3999, 337.118 )
( 3.19995, 290.86 ) ( 3, 249.037 ) ( 2.80005, 211.65 )
( 2.6001, 178.381 ) ( 2.3999, 149.232 ) ( 2.19995, 123.568 )
( 2.1001, 112.162 ) ( 2, 101.389 ) ( 1.8999, 91.2501 )
( 1.80005, 82.0617 ) ( 1.6001, 65.2692 ) ( 1.5, 57.9818 )
( 1.30005, 44.9914 ) ( 1.19995, 39.2882 ) ( 1, 29.4662 )
( 0.75, 19.961 ) ( 0.600098, 15.2084 ) ( 0.399902, 10.4557 )
( 0, 8.87154 ) ( 0, 8.87154 ) ( 0, 8.87154 )
on
You got all the main stuff there it's just not displayed as fancy as it is with the Tweecer. You definitely need a wideband to do any tuning, otherwise you'll never know if what you're doing is improving things or not. Here are a couple screen shots from Binary Editor.. that's the software I am using with the Tweecer. Everything is displayed in tables and graphs and it also has a dashboard to display all the parameters being dataloged in real time. I'll get a another screenshot of that and post it too.
http://farm3.static.flickr.com/2499/...c8915b85_o.jpg
http://farm3.static.flickr.com/2790/...04708829_o.jpg
#29
on
Here's the dashboard shot I was talking about. The software accepts the wideband O2 data from several popular devices like the LC-1 so it can be displayed and datalogged along with everything else. Engine was idling when this was captured.
BE_Desktop1 on Flickr - Photo Sharing!
#30
