List of axles by year?
Is there a list somewhere of the axles used by ford through the years to the present, and their brake and gearing configuration?
Like my 1991 10.25.
There are two configurations that I am aware of a semi floating and a full floating, there are also 2 1/2 inch wide rear shoes and the 3 inch wide ones.
I believe the 3 inch shoes were used on the full floater axles.
Anyone have a link?
Like my 1991 10.25.
Anyone have a link?
Found a good/useful link
I found a good/useful link.
Here is a complete list of quite a few axle makes including everything used in ford trucks throughout the years.
It does not list the brakes though.
http://www.ringpinion.com/DiffTypes.aspx
The following users liked this post:
Ford 7.5 inch
10 bolt rear cover with 7.5" ring gear.
Has c/clip axles with 28 splines.
Used in Models:
Bronco II: 1984 - 1990 (Rear)
Ranger: 1983 - 2005 (Rear)
Ford 8 inch
Drop out style rear end with 8" ring gear.
Has removable pinion support on the front.
Uses 28 spline axles.
Used in Models:
Ranchero: 1964 - 1978 (Rear)
Ford 8.8 inch
10 bolt rear cover with 8.8" ring gear.
Rear applications have c/clip axles in both 28 and 31 spline.
Front applications are in late model IFS Ford's and will have 28 spline axles using CV joints.
Used in Models:
Bronco: 1987 - 1996 (Rear)
Ranger: 1990 - 2005 (Rear)
E150: 1983 - 2006 (Rear)
E250: 1983 - 1998 (Rear)
F150: 1959 - 1987 (Rear)
F150: 1983 - 2006 (Rear)
F150: 1997 - 2006 (Front)
F250: 1997 - 1999 (Front)
Ford 9 inch
Drop out style rear with 9" ring gear.
Available in both 28 and 31 spline.
Has removable pinion support.
Used in Models:
Ranchero: 1957 - 1979 (Rear)
Bronco: 1966 - 1986 (Rear)
E150: 1961 - 1987 (Rear)
F100: 1957 - 1979 (Rear)
Ford 9.75 inch
12 bolt rear cover with 9.75" ring gear.
Has 34 spline c/clip axles.
Used in Models:
F150: 1997 - 2006 (Rear)
Ford 10.25 inch
12 bolt rear cover with 10.25" ring gear. most applications were full floating however some applications do have c/clip axles.
Differentials older than 1993 will require a new yoke to be compatible with a new ring and pinion.
Used in Models:
E250: 1985 - 1998 (Rear)
F150: 2000 - 2006 (Rear)
F250: 1985 - 1998 (Rear)
F350: 1985 - 1998 (Rear)
Ford 10.5 inch
12 bolt rear cover with 10.5" ring gear.
Has full floating axles.
Used in Models:
F250: 1999 - 2009 (Rear)
F350: 1999 - 2009 (Rear)
Dana Spicer D28
10 bolt front cover with 27 spline.
Found in mid-size Ford front applications.
Used in Models:
Bronco II: 1984 - 1990 (Front)
Ranger: 1983 - 1989 (Front)
Ranger: 1993 - 1997 (Front)
Dana Spicer D44
10 bolt cover with 8.5" ring gear.
Found in both front and rear applications.
Rear applications use a bolt in axle.
Axles are 30 spline. Front applications came in both standard and reverse rotation.
Used in Models:
Bronco: 1971 - 1977 (Front)
F100: 1948 - 1979 (Rear)
F150: 1967 - 1996 (Front)
F250: 1959 - 1989 (Front)
F350: 1979 - 1979 (Front)
Dana Spicer D50
Ford front end, found in both straight axle and independent front suspensions.
Often confused with a Dana Spicer 60.
Please check your bill of material numbers for proper identification.
Used in Models:
F250: 1980 - 2004 (Front)
F350: 1980 - 1986 (Front)
Dana Spicer D60
10 bolt cover with 9.75" ring gear.
Found in both standard and reverse rotation.
Axle spline counts range from 16 to 35.
Used in Models:
E250: 1969 - 2002 (Rear)
E350: 1988 - 2001 (Rear)
F100: 1965 - 1971 (Rear)
F250: 1954 - 2002 (Rear)
F250: 1978 - 1979 (Front)
F250: 2002 - 2006 (Front)
F350: 1979 - 2003 (Front)
Dana Spicer D61
10 bolt cover with 9.75 ring gear.
Looks like a standard Dana 60, but has a different offset for the carrier and therefore will require modifications in order to run certain ratios.
Used in Models:
E250: 1974 - 1984 (Rear)
Dana Spicer D70
10 bolt cover with 10.5" ring gear.
Has full floating axles with 30 or 35 spline.
Used in Models:
F350: 1961 - 1983 (Rear)
Dana Spicer D70-HD
10 bolt rear cover with 10.5" ring gear.
Has full floating axles with 35 splines.
HD has larger pinion and carrier bearings than a standard Dana 70.
Used in Models:
F350: 1980 - 1997 (Rear)
Dana Spicer D70-U
Has full floating axles with 32 splines.
Has smaller pinion bearings than a standard Dana 70.
Used in Models:
E250: 1983 - 1997 (Rear)
F250: 1983 - 1997 (Rear)
F350: 1980 - 2002 (Rear)
Dana Spicer D80
10 bolt rear cover with 11.25" ring gear.
Could have 35 or 37 spline axles.
Later model fords use different pinion bearings than all other models.
Used in Models:
F350: 1988 - 2009 (Rear)
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Ford 9 inch
Used in Models:
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
One more I forgot, oh so long ago.
Ford 7.5 inch
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Ford 9 inch
Used in Models:
Ford 9-3/8 inch, sometimes called a 9-1/2”
Drop out style rear with 9-3/8" ring gear.
Can be put in the 9” housing and looks nearly the same as the 9”, but parts do not interchange.
Available in 31 spline.
Used in Models:
F-100 1/2 Ton: 1964 - 1975
E-150 1/2 Ton: 1975 - 1976
F-150 1/2 Ton: 1964 - 1975
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Ford 9 inch
Used in Models:
Used in Models:
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
Here's a couple of updates.
On Bronco the change from 9" to 8.8" was 1983.
1983 = 9"
1984 = 8.8"
I recall thinking I should buy one a year old to get the 9" but my 8.8 turned out fine for all I did with it, except driving beyond axle deep through a river once.
FWIW my 84 came with a D44 front, thought they all did.
Cheers,
- Jeff
1983 = 9"
1984 = 8.8"
Cheers,
- Jeff
I just assumed the site I got it from had it right.
Ford 7.5 inch
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Bronco: 1983 - 1996 (Rear)
Ford 9 inch
Used in Models:
Bronco: 1966 - 1983 (Rear)
Used in Models:
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
Ford 7.5 inch
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Ford 9 inch
Used in Models:
Used in Models:
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
As always, if anyone knows of a correction, just let me know.
Ford 7.5 inch
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Bronco: 1984 - 1996 (Rear)
Ford 9 inch
Used in Models:
Bronco: 1966 - 1984 (Rear)
Used in Models:
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
__________________
Ford 7.5 inch
Used in Models:
Ford 8 inch
Used in Models:
Ford 8.8 inch
Used in Models:
Ford 9 inch
Used in Models:
Used in Models:
Ford 9.75 inch
Used in Models:
Ford 10.25 inch
Used in Models:
Ford 10.5 inch
Used in Models:
Dana Spicer D28
Used in Models:
Dana Spicer D44
Used in Models:
Dana Spicer D50
Used in Models:
Dana Spicer D60
Used in Models:
Dana Spicer D61
Used in Models:
Dana Spicer D70
Used in Models:
Dana Spicer D70-HD
Used in Models:
Dana Spicer D70-U
Used in Models:
Dana Spicer D80
Used in Models:
__________________
I'm not an expert on all the models and their variations (understatement).
What I found on the TTB.
The TTB front axles are variations of the Dana 28, Dana 35, Dana 44, and Dana 50.
Common applications.
1980–1997 F-150/F-250
1980–1996 Ford Bronco
1983–1997 Ford Ranger
1984–1990 Ford Bronco II
1991–1995 Ford Explorer
They say that this is an incomplete list referring to common applications only.
