6.0 oil pan change
fibreglass tends to be somewhat brittle especially as it ages and is exposed to the level of heat of the oil. if i was going to try patching the pan i would rather use something like POR putty that is intended to bond to somewhat rusty surfaces and will be more pliable. yes if it hasn't actually started leaking yet, some treatment to seal the metal might give you a couple more years.
no need to be sacastic. if the pan is rusting but not yet perforated or leaking, sanding it and putting a seal coat of epoxy or POR 15 is no different than painting it in the first. other than using a product that is 10 times better than the cheap crap ford uses. coarse if they used better metal this wouldn't happen nearly as often. what do you mean only 15k engine. first off the odds of the pan failing catastrophically after repair is next to nil. about all it would do is leak inspite of repair, and if you lost enough oil to lose pressure the injectors wouldn't be able to fire so it would stop running. i've heard of guys not putting the drain plug in properly and losing it at 60 mph. got another plug, filled up again and carried on, no issues
It's also a HEUI system so typically the injectors will fall off before any motor damage is done from low oil. Since we don't know the exact condition of his "bad shape", I see no reason not to bring up ideas like POR as an alternate to changing the pan. If you saw bubbling paint and surface rust on your pan would you change the pan?
YEah your right I wasnt clear, In an instance like just a surface rusting pan sanding and using POR would be a great thing to do to preserve the pan. However I have seen posts about rust HOLES, and self inflicted holes, guess thats what I was aiming towards.
madmedic8526
1999 to 2016 Super Duty
03-14-2016 02:40 PM
CoastyAV8R
01-13-2016 04:29 AM
jrockdiddy
07-13-2015 08:37 AM
