Looking for opinion's on a 5.0 to 5.8 swap
Okay ,here's the skinny . I went and looked at the 91 f250, 5.8, 2 wheel drive. It does have the OD button on the dash.It started rite up , no smoke idled high for about 2 min. then drove it seem to run very well. valve cover gasket's are leaking and i think the rear main seal is leaking. Looks like it has been leaking for awhile. built up on the exhaust pipe and the tranny is covered in oil and built up dirt.
Here is the vin # 2FTHF25H1MCA84954 so if you guys have the way to know what it is please let me know or let me know where to get the info it would be great.
So , i am under the impression that i should be able to drop this motor and computer into my truck with the stock wiring harness. All the plugs should be the same and have no major issues.
If i am wrong about this info someone please let me know......
Oh where can i get a list of engine code's that tell me what they are??? thanks
two problems with it i see are that the 5 speed you have assuming its the stock mazda wont hold the 351 for long. they are pretty weak. and the 302 computer in your truck will run the 351 but wont have alot of power because of the displacment difference. or you could just transfer the motor trans wiring harness and computer from the parts truck to yours. i dont know if the computers will just swap, and if so you will have check engine lights because it will be looking for an automatic trans. at least my 96 did.
The 302 fires 1-5-4-2-6-3-7-8
The 351 fires 1-3-7-2-6-5-4-8
I''ve successfully swapped computers from auto trucks to 5 speed trucks and never had an issue.
So i am a little up in the air.....Yes i will have the computer... i am picking up a driving 91 F250, 5.8, auto, 2wd , with the overdrive button on the dash... the truck is in working condition and will drive it home.
My plan was to swap out the motor and computer into my truck with the stock wiring harness...
Also doing some minor repair's while i have the motor out , ( i.e.) header's, ignition coil , plugs , wire's, cap, rotor,valve cover's, etc,
So , should i look for a different putter or what ?
You guy's are my only source of reliable ford info, should i look for a truck that had a c6 tranny .
The reason i am concerned, is the truck has to go through emission's and in CT if you have a check engine light on they automatically fail your vehicle.
I am trying to do this the right way..
Fungus232
13
05-12-2015 10:55 PM
onthefloor4x4
20
04-07-2011 09:43 AM
