Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape Automatic start
Old Nov 17, 2009 | 11:30 AM
Hendrixx's Avatar
Hendrixx
I have an 91 f150 with the automatic start and I would like to put it on my 01 Escape but I need the wiring diagram because its different between the two. Does anyone know if this will work? and any diagrams?
Old Nov 18, 2009 | 12:27 PM
Hendrixx's Avatar
Hendrixx
ANYTHING would be appreciated. 20 people and still no answer at all??? HELP!!
Old Nov 18, 2009 | 01:38 PM
mike_s_82's Avatar
mike_s_82
2001 Escape Automatic Start
For starters, the Escape has PATS and the F-150 does not. You need to contact the manufacturer of the auto starter and see if it was compatible with PATS and if the PATS add on module is still avaible. They should have the wire diargrams for the module as well as simplified diagrams for the vehicle and where to tap into the wire at.
If it was a Ford module, thay were made by code alarm, and in my opinion of using 2 of them, you are better off just buying a new aftermarket one. I did that for a Blazer, and it was hassle free and had a lot farther range.
My 2003 F-250 came with a low end code alarm, and it's range is low as well.
rickfar
Dec 6, 2011 04:16 PM
guliver
Mar 19, 2011 11:17 PM
AC94EXPLORER
Jan 1, 2009 09:15 AM
