Snow tires + ?
Old Nov 16, 2009 | 10:04 PM
7.3 Rocket's Avatar
7.3 Rocket
Snow tires + ?
We (family business) recently bought a 1995 7.3 4x4 SRW with a plow frame on it and we intend to use it as our plow truck.
My issue is this:
The front tires are worn far more on the inside edge than the outside edge. I'm going to imagine this is caused by one or more of the following 3: bad shocks, bad BJs, bad alignment
We'll attempt to remedy the tire wear issue and then put new tires on the truck. Any suggestions on a good snow tire?
Thanks again.
Old Nov 17, 2009 | 12:42 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Depends on your budget. I have had excellent luck with this on all my fleet vehicles.
Nokian Hakkapeliitta LT
Old Nov 17, 2009 | 10:56 AM
Passin Thru's Avatar
Passin Thru
Im running Michelins and AIRLIFT. The added weight of a snowplow when you figure in Moment is about 2500 lb probably due to being so far fwd. Put the snowplow on a tractor w/cab. :>)
Old Nov 17, 2009 | 06:14 PM
7.3 Rocket's Avatar
7.3 Rocket
Unfortunately a tractor with cab just isn't an option. Distance between facilities that need to be plowed out is just far too great.
It's probably a half hour drive in a truck to get between the two farthest locations so a tractor is just not an option. Really need something that can move quickly and push snow. A 7.3 fit the bill.
Old Nov 17, 2009 | 06:55 PM
ckal704's Avatar
ckal704
Uneven tire wear caused by a bad BJ?? Is there such a thing?
Old Nov 18, 2009 | 08:26 PM
Red97350's Avatar
Red97350
I'm assuming that it's a 350 because you referred to it as srw? So that would mean that it has the D60. I would think that bad ball joints could lead to uneven tire wear, but might that scallop the tires more?
Red
Old Nov 19, 2009 | 01:50 PM
foxracing0934's Avatar
foxracing0934
If its only going to be a plow truck then I would just use some Uni-royal Laredo's that are the stock, 235/85, size and just throw 1500-2000 pounds in the back. That truck will plow any parking lot that you put it in all day long and never be a problem. I have been running this set up for 3 years now and i never have a problem, only difference being that the weight sometimes comes from a sander. Just remember that no matter what kind of tire you go with the stock size is as good as it gets for the snow, the fatter tires do not work as well.
Richard
parkland
General Automotive Discussion
Apr 18, 2014 10:28 AM
chrison600
Apr 6, 2012 09:00 AM
dyhrdford
Dec 22, 2008 06:43 PM
woody1003
Aug 24, 2004 04:03 PM
