FREE FLUID FILM SAMPLES!
on
I used some inside the doors of my 73 crewcab since moving to the coastal areas, most doors rust out from inside, so i think im saving them until i can shoot some permanent coating in there. It definately sticks longer than anything else i have used.
How long should it last inside a door do you think?
Any members who still haven't tried it can PM me for a free can. Those who have purchased after getting a sample can get a free shirt or hat by posting a pic with a regular sized can on their equipment.
Fluid Film
I like it, Bought a large spray can to spray all of the inside of my doors while I have the panels removed. Now if I could buy the one gal can with the spray nozel and a long tube it would be great. Well as soon as I find the 5 gal can on line with reasonable shipping I will be under the truck spraying. Have two trucks to do, one now and one next summer. It seams to kling to everything, including the window glass.
Thanks for the free sample.
Dan
Thank you for the sample can, I just tried it on the the new running board brackets/bolts etc. Will see how it works as they Road Dept has just started sanding and coating the roads around here, Freezing POGO Nip Fog and 12" of the white stuff on the ground along with -15* lowest temp so far.
A word to the wise, FF tastes like S--T, I coated some of the running board bolts and then without thinking, popped a coated bolt into my lips to hold for a second untill I could get a free hand, YUK, at the least you could have a better tasting favor.
Even coffee strong enough to float a horseshoe would not kill the taste.
Thanks, will report how well it works in a couple of weeks after the snow disappears. Is there a online site, to buy from as the nearest dealer is over 150 miles away.
Don
Don
#28
#29
Well add me to the list of people who are amazed..
I have used it a couple of times now, but yesterday saw real results..
The sliding bolts on my minute mount plow were rusted and hard to move..
Then I remembered the fluid film and gave them a shot..
I could seee the fluid film bubbling up like it was acid..
Later I looked at the pins and they look brand new..
I should have taken a before and after picture, but didn't think of it then..
#30
Dan
Don
Don
Don't worry, at least it's non-toxic.
Follow this link for our online dealers.
