Can't identify motor...
Old Nov 15, 2009 | 10:24 PM
dieselac's Avatar
dieselac
Ive been researching the past couple weeks on the site and I cant seem to Identify my engine. I have a 73 F100 put the motor has been swapped (according to who I bought it from). The only label I can really make out is on the driver's side header. Its pretty rusty, but from what I can see it reads (DSD E-GAB1-BA). Now that may be wrong, but I know for sure the DSD E is right. Can anyone help me please? Maybe I am looking in the wrong place? Thanks.
Old Nov 16, 2009 | 04:20 AM
miottimouse's Avatar
miottimouse
post a few pics showing the water pump and the valve covers should be able to help if we can see what you have regurds joe
Old Nov 16, 2009 | 08:30 AM
Blown 331's Avatar
Blown 331
How many valve cover bolts on each side? That should narrow it down a little bit. But as stated above pics would be nice.
Old Nov 16, 2009 | 05:42 PM
dieselac's Avatar
dieselac
Do these help? I can take more if need be. Looks like there are 6 bolts to me.
Thanks
Old Nov 16, 2009 | 08:14 PM
peganit2's Avatar
peganit2
looks like a 302 to me, judging from the style of ancillories. A 70's 302.
Old Nov 16, 2009 | 08:18 PM
460/5's Avatar
460/5
Zombie Survivalist
i agree. 302. if is was indeed swapped in, may even be a 289, but most likely a 302.
Old Nov 16, 2009 | 08:40 PM
Fordworth's Avatar
Fordworth
Could also be a 351 Windsor if you're lucky.
Old Nov 16, 2009 | 10:27 PM
dieselac's Avatar
dieselac
Took off the valve covers tonight and it is indeed a 302. Thanks for everyones help. There were some casting numbers underneath on the block itself, the passenger side had an upside down B and OLIO above it. The drivers side had the upside down B as well but a OL5 above it. Both sides also had a circle of letters and numbers reading L8185(dont know where it should start or end....in a circle). Anyone know what all that means? I was assuming it was just for assembly purposes, but does it mean something else?
Old Nov 17, 2009 | 12:34 AM
pat67shorty's Avatar
pat67shorty
The casting number for the block is actually above the starter on the side of the block, near the oil pan rail.
Old Nov 17, 2009 | 09:15 PM
kwemj 67's Avatar
kwemj 67
Smile
Those numbers are date codes, so 0L10 is December 10 of 1970. 0L5 is December 5 1970. So came out of a 71 production vehicle. Don't quite understand the L8185, where was this located and was it a cast stamping?.
Old Nov 17, 2009 | 09:33 PM
dieselac's Avatar
dieselac
Thanks for the info! Where did you find that at? The L8185 was on the block between the first and second cylinders (assuming you are looking at it left to right). They were in a circle, so I dont really know which character is first and which one is last.
