7.5L Ford 460 Oil Cooler Heat Exchanger Failure
#31
BPM, have you changed yours? I am trying to decide which way to go with mine. The filter reloactor from Ford doesn't look like it will move the filter far enough forward for the crossmember, but maybe it will. For the few extra dollars, I kind of like being able to fully remote mount it wherever. Especially for the safety of the filter in a 4x4 like mine.
Could a person not just run the new lower radiator hose to bypass it and just cap the coolant ports, thus just having the oil filter relocated yet, but not having any chance of the coolant getting in the oil or vice versa??
Brian
#32
#33
Brian,
I am thinking of doing the same setup on my mud truck. I noticed alot of oil around my oil cooler lately, so If I have to remove it, I want to bypass it all together. I was wondering why the JIC fittings versus leaving it half inch pipe swival? I have 1/2 gates megahose at work, I will see if I can get a temp range for you.
Rich
Rich
#34
Brian,
Rich
Rich
Brian
#35
Thanks for the reply Brian. I use the same hoses and crimp fittings at my work (CarQuest). I have not gotten a chance to fab my setup yet . I am
going to use a Hayden kit #77023. I am also going to use a Wix (CarQuest no.85773) oil filter which is listed as a 2qt Ford Filter. I however, doubt it is a true 2qt filter, since it is less than half the 85515 filter length longer. I found a hi flow oil filter adapter for the block for around $20 online. I also plan on switching to synthetic oil . Hopefully with the larger filter and synthetic oil, I shouldn't have to run a oil cooler.
Rich
Rich
#36
#39
#40
Great Info!! Thanks... I have my 1996 F350 4x4 Crew Cab 460 V-8 partially apart right now trying to replace the darn lower radiator hose from water pump to oil cooler. I cannot believe I am going to have to remove the water pump or the oil cooler!!!!! Just a ittle more clearance and the hose could be replaced like any other hose. STUPID FORD ENGINEERING DEPARTMENT..... The reason I am doing this is because my tranny fluid cooler internal to the original radiator gave out and mixed tranny fluid with coolant.... NOT GOOD. I know for a fact that it happened in the last 700 miles but when?? And I am worried sick anbout the tranny.... Only 100,105 miles on the truck, brand new tranny installed at 65,000 miles due to early model E4OD seizing up on me.... So, I see yor engine oil cooler mods. I do not want to mix coolant and engine oil. So now I am confused and worried about this and am thinking that maybe I will jerk the oil cooler and use a kit with no cooler as you guys are doing. I live in AZ where ambient gets 118 degrees and road temps are 180+ coming from the asphalt during the summer. So I am a bit worried from that point of view. Decisions. Decisions. Any thoughts?? I think I am going to stop and leave the truck sit for a few days while I ponder my thoughts and new direction....... Thanks for any thoughts that you might have!
#41
I have decided to buy the lower rad hose that you guys referenced for 1990 F250/351 and get everything hooked up again but bypass this oil cooler and just leave it in place for the moment. I need to get my tranny circulating and change that fluid out a few times to save the tranny. Meanwhile I'll figure out what I want to do. I am seriously considering the Ford Racing adapter #M-6880-A50 and totally removing the oil cooler. I don't really pull anything with it and it is hardly ever loaded down. Just basically a "driver"..... But I am still interested in your opinions and thoughts, and what did you end up doing with your truck in the long run? I need to make a permanent decision eventually....
#42
On mine I have not changed anything. I am using custom made hydraulic hoses with a remote mount filter. I have looked at the ford motorsport setup, it has 1 flaw, it can let the filter drop down (nothing indexes it and keeps it in place like the oe setup. I would like to find the oe part number for the version without the cooler, because that would locate everything properly.
#43
#44
Well things don't work out like I want them to. For anyone else thinking about making this change before you mix oil and water, I can't just use the early model radiator hose and leave the stock oil cooler in place because the oil filter on the oil cooler is in the way of the radiator hose. Murphy's law is definitely shining here. Unbelievable. So I am taking the oil cooler loose to get the stock hose replaced until I buy the other parts. I will come back to this, because I don't want oil and water mixing. This engine is super strong and uses NO oil between changes with 100,000 miles on it. I still dislike this engine oil cooler design for replacing the radiator hose. What an engineering mistake!
#45
Thanks for the Info. It was very usefull. I had the same problem today and decided I was gonna beat it my own way. I just drilled the factory adapter for AN8 and am making a hard line to go between. I have a remote oil cooler on my VW and the hoses just dont last very long. I have use many different lines and it always comes down to Parker Press lock High temp lines.
Any reason this wont work.? I'm in it ZERO $ besides the fittings that I already had.
