Doing Injector O rings Tonight
Old Nov 12, 2009 | 11:34 PM
strokin'_tatsch's Avatar
strokin'_tatsch
if the o-rings were your problem then you will just get a smoother running truck. straight pipe you will get a decent exhaust note. if you really want the exhaust to sing to ya then throw some stacks on it!!! haha. are you going to do the downpipe? if you do then you will see a slight performance increase from it.
your doing a good job so far man, only one phone call and a few text messages. keep up the good work. when you go back together with it MAKE SURE YOU TORQUE THE INJECTOR HOLD DOWNS!!!! don't just guess at them.
Old Nov 12, 2009 | 11:39 PM
MustangMatt96GT's Avatar
MustangMatt96GT
Do you know the value at all? BTW I have NEVER used a torque wrench on anything but Head bolts and studs.... I know values pretty good, but I will use the torque wrench on it... What is the value.
strokin'_tatsch
the injector hold down torque spec is 120 in lbs.
Old Nov 13, 2009 | 01:26 AM
MustangMatt96GT
Well.... I know better than to crank the engine without the gaskets between the valve covers and the head... geazuz.... I figured it would keep that all contained basically... guess not.... I have more than a quart on the ground now... LOL not only that but now my exhaust manifolds are COVERED in oil, so it should be for a nice smoky start... LOL
But tomorrow morning all I have to do, is put the Glow plugs back in it, and fire it up!
Old Nov 13, 2009 | 10:44 AM
MustangMatt96GT
So, how much smoke should I have, and how long should it last? it smokes while like a freight train.... here are some videos...
how long will this last...
http://www.youtube.com/watch?v=hvkW7CCStW8
http://www.youtube.com/watch?v=VzLxsv96vcI
Old Nov 14, 2009 | 07:30 AM
WALJON's Avatar
WALJON
Wow that's a lot of smoke! I don,t think that is normal I have changed o,rings on several trucks now and never seen that much smoke.
Old Nov 14, 2009 | 09:26 AM
strokin'_tatsch
did it clear up completely Matt???? Also did you use like carb cleaner or something to clean the injectors up with? that may have been the problem if u used carb or brake cleaner to clean the injectors up. don't hurt anything, but my stage 1's didn't smoke white. these stage 2's were sprayed out with carb cleaner before i got them, and they smoked horribly for awhile like i told you.
Old Nov 14, 2009 | 09:37 AM
MustangMatt96GT
yep all the smoke is gone.... Thanks for your help travis...
Old Nov 14, 2009 | 10:08 AM
strokin'_tatsch
Its not a prob man. if you were down here i woulda dove into it with u like we do everyone else. haha. glad you got it done and glad i could help man
Old Nov 14, 2009 | 10:54 AM
MustangMatt96GT
Now, im off to go get an exhaust clamp, and IM going to get my exhaust striaght piped today! and then ill do a down pipe, and then a chip! Should be done for a while... but I think Im going to try and get that rough idle away. I got some IPR o Rings that I will have monday, so we will see what that takes... I just really dont want to take out the fuel bowl... I will tear into the engine no problem, but im not a fan of that fuel bowl, eventually I want to do an electric fuel system.
Old Nov 14, 2009 | 11:17 AM
c00nhunterjoe's Avatar
c00nhunterjoe
glad to see you got it back together. they will smoke like that for up to 15-20 miles before they clear up sometimes.
Old Nov 14, 2009 | 11:26 AM
strokin'_tatsch
Joe, did i get bonus points the other night?????? haha.
nobody guessed up on the bore x stroke. hahaha
Old Nov 14, 2009 | 11:34 AM
  #28
c00nhunterjoe
lol, yes bonus points for you, i forgot all about that. and to answer your question, the 7.3 bore and storke is 4.11x4.18, and did you know that the 6.9 uses the same stroke crank? just a slightly smaller bore of 4.0
Old Nov 14, 2009 | 11:51 AM
  #29
strokin'_tatsch
yep, and bonus points for Joe!!! we r tied there slick. haha. ya i new the 6.9 used the same crank with the smaller bore. then the bore was pulled up to the 7.3 4.11". but the IDI's also had a compression ratio of what? 21.5:1??? and we are down to 17.5:1. then i think the 6.0 was up to like 18:1 or something...
Old Nov 14, 2009 | 11:59 AM
  #30
c00nhunterjoe
yup, 21.5 but if i recall the first 2 years were only 20 to 1, all 7.3 idi's including the turbo model in 94 was 21.5 the 6.0 is more then us at 18 to 1 and the 6.4 is less at 16.5 i think
