99 F350 no crank problem
I am having no crank problem with my 99 7.3. It has been coming on for a couple of weeks where the relay on the passenger fender will just click when trying to start. I usually let off of the key and try again and it will start but not tonight, it just clicks. I checked for voltage when trying to start and have power at the relay, I then checked at the solenoid with a test light with someone turning the key and it lit up, so I assumed that the solenoid was bad. I just replaced it and still have the same issue. I tried to jump the large terminals on the right fender but it still won't start. This is just my luck, I was leaving at 5:00 am to travel 850 miles to pick up my new project of a 1956 F100. I am desperate for help, cause I really want to leave and pick up my new toy. Thanks in advance.
