V-code spring upgrade questions
Old Nov 20, 2009 | 02:26 PM
  #76
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
so it turns out I BLEW IT on a customers order and sent him too short of U-bolts.......
sold him the 320mm/12.598in ones and they were to short..
not sure how I did it but now I'm eating a little crow......
I'm not perfect after all and made a mistake and now must confess to my peers!
dam!
lol
i'm going to fix it.
but dam! dam! dam!
that is all!
Old Nov 20, 2009 | 09:47 PM
  #77
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
starting my spring swap tonight, pics and mesurments tocome!
Old Nov 20, 2009 | 10:17 PM
  #78
VR6Nutt's Avatar
VR6Nutt
dam!
lol
but dam! dam! dam!
that is all!
Was this the part number of the U Bolt: N811667S436 ??
Old Nov 21, 2009 | 02:08 PM
  #79
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i'm going to make a post alittle later, i put my X codes on and they gave me almost 3" of lift. i have to get the 350 blocks now because it sits really *** low haha
the ride is so much nicer!!
Old Nov 23, 2009 | 12:40 PM
  #80
Parts Guy Wyatt
Former Vendor
yes, which I've sold many times with these blocks. must be a year thing cause I did it before about 6 months ago.
So I think the best thing is to always go with at least the
343 = 13.50 in p/n N803770S436
or
360 = 14.163 in p/n F81Z5705EA
ed
Old Nov 27, 2009 | 02:24 PM
  #81
kkology's Avatar
kkology
If you install the new 3.5" rear blocks (of course after the V-code front springs were done) what is the Ford OEM part number for the new U-bolts and nuts you need to put back axle under the truck?
Help,
Keith
Old Dec 2, 2009 | 01:02 PM
  #82
Parts Guy Wyatt
Former Vendor
little bit of info for you on rear u-bolts when adding the 4" blocks.
I'm dealing with a customer now that unfortunately I blew it and sent wrong u-bolts not once but twice.......
he is being a nice guy about it but I want to share this info.
if you have a F250 and are adding blocks from the F350 and have no aux springs you can use/need N811667S436 which are 320mm or 12.598 in long
if you have the F250 with aux springs you need N803770S436 which are 343mm long or 13.503 in long
do not use the F81Z5705EA which are 360mm long, my cust says they are too wide and hence why the second ones I sent were wrong.
I did not know they were too wide and seen somewhere in this post where I thought someone said they ordered and used this part number....
I dont recommend that program as you will be in same boat I'm in now.
I would have sent the 343mm the first time but I blew it and missed the fact he had aux springs..... my bad.
I have this info branded into memory now.
ed
Old Dec 2, 2009 | 06:49 PM
  #83
Stewart_H's Avatar
Stewart_H
Ed, what are the part numbers for just the "standard" OEM F250 4x4 rear U-bolts that came on the truck from the factory?
Stewart
Old Dec 3, 2009 | 12:00 PM
  #84
Parts Guy Wyatt
Former Vendor
Stewart
if you had aux springs on the F250 its N811667S436 and they are the 320mm
if you didn't have the aux springs then they were N804420S436 289mm
so I screwed the pooch on this one..
Old Dec 5, 2009 | 04:19 PM
  #85
kkology's Avatar
kkology
Ed,
Thanks for the info. I have both rear blocks (F81Z*5598*FA left & F81Z*5598*GA right) and have installed the V -codes spring in the front. The suggested rear springs to help smooth the ride for the rear were B -code springs # 3C3Z*5560*CB. If this is true,
on my 2004 Excursion 4X4 Eddie Bauer 4X4 diesel, which U-bolts should be used? The N811*667S*436 or the N803*770S*436 and what is the OEM numbers for the nuts? The parts numbers for the U-bolts seem to be for a set of 4 U-bolts, is that correct? Now I'm ready to find shocks for this lifted Excursion, any thoughts?
Old Dec 7, 2009 | 02:26 PM
  #86
Parts Guy Wyatt
Former Vendor
those springs are w/o aux so you are ok to use N811667S436 UBOLTS for the rear. order qty 4
N620485S56 is the part number for the nuts.
ed
Old Dec 7, 2009 | 05:28 PM
  #87
kkology's Avatar
kkology
Are these rear springs any different than what came on the truck from the factory. If not does Ford have a rear spring that will help like the V-code in the front? Or should I just re-use the springs that are there now with the new blocks?
Old Dec 7, 2009 | 05:57 PM
  #88
housedad's Avatar
housedad
kkology-
The B code springs are different than the stock Excursion springs. Different shape, design and load rating.
You CAN use the factory springs, but most people change to the B code to get a better spring rate and ride.
Ford does NOT sell a spring that lifts the rear like the v code swap.
Options for the rear:
F-350 3.5" tapered spacer block stock springs. Brings rear up to near level. Ride still very mushy
F-350 3.5" tapered spacer block B or F code springs. Brings rear up to near level. Ride MUCH improved.
Stock springs or B code springs with Add-A-Leaf. Bings rear up to level or more. Ride improved with stock springs. Ride stiffer with B codes.
B codes with 2nd leaf from old Excursion springs added in the spring pack. Brings rear up 2.25 inches. Stiffer ride than B codes.
Do a search here in the Excursion forum and you sill find that almost all of your questions have been answered at some time or another.
Bion
Old Dec 7, 2009 | 06:12 PM
  #89
Parts Guy Wyatt
Former Vendor
bion has said it all.
very nice!
Old Dec 13, 2009 | 12:24 AM
  #90
WillW4169's Avatar
WillW4169
Originally Posted by BostonX73
I went with the X Codes on my as well, since I got a great deal on them. Mine had an add-a-leaf already installed on them. I ended up with about 4" lift in the front with the two.
Ride is a little stiffer, but I also put on the HD 5100 Bilstein shocks too. If you are going down the highway and normal roads it works great.
You mostly notice it on the gravel/pothole roads. the combo absorbs them well, but is stiff doing it. It's still an improvement over bottoming out on the bump stops.
BTW - we all need a garage like forests!
I'm considering the X codes, too. Got any pics?
