96 Ranger Sensitive Front Brakes - ABS
So a Freind of mine just bout a 1996 Ranger V-6 ABS with only 50,000 miles on it. When you press on the brake pedal at slow speeds (5-10mph) the front wheels want to lock up. The stopping starts at the very top of the brake pedal push. At high way speeds you just barely touch the brakes and they start to stop.
The ABS light is not on. It comes on during start up and then goes out like normal. I looked at the front pads and rotor. No gouges in the routers, and the pads have plenty of life left to them. It does not make any odd noises when you press on the brakes, it does not pull to one side or the other, straight as an arrow. Vacume seems good, fluid is up to specs.
What could be causing this? and How do I fix it myself? Thank you for your input.
I like pgw85706's idea to check the front wheel speed sensors.
Look for debris on them or the rotor, or for chips, cracks or missing reluctor vanes.
If all that checks out ok, look in the Tech Info thread atop this forum & scroll down to the brake section, to see how to pull any ABS system trouble codes, then post All ofthe code numbers found.
pg409
10-17-2007 01:14 PM
jonvhall
04-22-2002 01:27 PM
