need serious HELP wth 2000 F450 triton v10
first of all truck all of a sudden had trouble starting had to crank couple times (never before) then driving along on highway when all of a sudden dead! thought out of gas, put gas in,nothing just kept turning over no fire up. must be fuel pump or filter dropped tank on side of highway 3 times changed both pump and filters also had to buy that stupid special tool! still no start! towed it home, have now changed throttle positioning sensor,cleaned maf sensor,no start,UNPLUGGED maf it starts but if give it gas dies ran code check on it got P0113 and P0112 tried new maf did same thing! anybody know any ideas been down 2 weeks now even 2 mechanics still wont run??!! PLEASE HELP!!!!
I feel your pain, sorry I couldn't help.
However, if you're playing around your truck and want to help someone - I need help from an F450 owner.
I don't have an F450 but want to put F450 brakes on my earlier model F350. I want to have more stopping power with the 14.53 dia brakes of the F450.
Could you please tell me how the caliper hardware is bolted to the axle? Is it bolted directly to the steering knuckles? Or is it bolted to a caliper anchor plate (backing plate) that is sandwiched between the spindle and the knuckle? A closeup photo would be super if you could.
I hope and pray you'll solve your starting problem soon
Thanks,
Art
Thanks,
Art
I'm sure Redford's correct about the codes, but I don't think an IAT sensor can cause these symptoms.
Have you checked fuel pressure at the rail? That's where I would start. This would be to rule out the fuel system; I don't think your problem is fuel related. Most fuel problems won't kill it instantly unless that problem was instant pump failure. Since you replaced that, we have to look elsewhere.
How many miles on the truck? Have the plugs ever been replaced? What about COPs? Have you checked for a spark?
You may have something shorted out somewhere, have you checked your fuses?
Remember, if you have compression, valve timing, fuel, and a spark the engine HAS to run!
as far as I can tell think that is part of my maf which I tryed a new one didnt help at all also today tried starting wth the egr unhooked started and could drive it what the hell? why can truck start and drive when keep taking parts off but not with them on it has to be something relating to air system right? any ideas helpful! live hour at least to nearset town, whats a girl to do?! fix or be stranded?! HAVE to fix!!!
Tom,seems to be getting fuel also engine starts today tried unhooking EGR started idled good drove it into driveway put part back on dies! does that mean that is bad part?seems it is an air problem somewhere not sure though possibly the electrical thought though could also be have brand new heavy batttery but what ever this problem is drains it never had any problem wth truck until all of asudden dead while driving!?
Very strange...
This is sounding more and more like an electrical issue to me. I'm not sure how it's done, but I would see about getting your PCM tested. PCMs can go bad, and because it controls your entire powertrain, a sudden failure would leave you dead in the water.
I do NOT think this is an air intake issue, but I could be wrong. For something to completely kill the engine, then intermittently allow it to run for short periods of time before dieing again, it would have to be something that could be a problem in certain circumstances but not others, which would almost exclusively be an electrical issue.
All your fuses are good, right?
StangStang
08-23-2016 10:04 AM
crimson080
1997-2006 Expedition & Navigator
07-18-2016 09:09 AM
easygoin4
1983 - 2012 Ranger & B-Series
18
07-09-2012 01:28 PM
