We need some Heavy Duty Truck Pics!
#1233
I got this 81 F700 Fire truck about 2 months ago and sold it about a week ago to local fire department. I had some plans for it but came up with a better idea. It was a cool truck to drive. It will be put to good use in Pacific Northwest.
#1236
#1238
#1243
#1244
1952 Ford Coe: thank you much!
73F700: Thanks👍🏻. I should put a thread together & tell it's story, might be a chopped up mess of a thread though. I'm pretty certain this truck originally came with single hydrovac brakes just like every other 1970's F600 4x4 I've had the opportunity to look at. At some point the truck was fitted with a 1 3/4" bore dual reservoir master cylinder of unknown origins on a homemade bracket, & the second hydrovac booster also added. The plumbing of the 2 circuits is where it got interesting & confusing. 1 reservoir & booster went to the front brakes with the other reservoir going through a mico lock & then booster to the rear. After studying the '78 Ford shop manual I decided to strip the brake lines & start over following this diagram.
I've also purchased the differential valve shown in the diagram, replaced the rear booster & rebuilt the rear brakes, which was non-operational when I purchased the truck. I still need to get the correct master cylinder & will probably go ahead replace the forward booster too. I need to find the wire harness for the differential valve, stop light switch & brake warning lamp too. Pressure bleeder already purchased to tackle the 13 brake bleeders lol.
#1245
