going out of gear
going out of gear
i have aproblem with a1995 full size 351 bronco. when going down road the tranie will slip out of gear .the spedo will goe crazy .you can let off the foot pedal ,push back down on maybe the tranie will take hold maybe not . ill tell you up front ive hade it to several garages. it doesnt pull up any codes. any help would be helpfull. gary
going out of gear
If it has a E40D then it sure needs some looking at. Those were known for problems early on. If it is original, then it probably needs some work. Rebuilds are not cheap, especially if it gets all the "updates" done to it.
Good luck
Larry
1967 F100 352/c6
1969 F100 428CJ/4 spd
1959 B model Mack
and a few hot rod FORD cars too
Good luck
Larry
1967 F100 352/c6
1959 B model Mack
