1990 F-150 What to do
Well first thing you would need to figure out is how much $$$ you have to work with. Second would be whats your goals with the truck ? If your on a low budget and staying with the 302 or even swapping it with a 351 start with the basics like headers, exhaust, and a cam. the type of cam. would depend on what your goals with the truck. If you had more money to spend you could always get new heads, intake, bore it out, stroke it etc... once again depends on how much $$$ and your goals with the truck. You have to remember stock componets on the truck are ment for a stock engine, so you have to keep that in mind when you set the goals for the truck. Hopefully that helps you out my friend
I would agree... Keep the EFI. I think what 93F250tn was trying to get at is what are you doing with the truck? Pulling? Daily driver? 4x4 off road? You need to decided what you are going to be doing with the truck the majority of the time... IE: I have a F-250 w/ a 300 I6 and use it for some runs to the lumber yard and out hunting... I don't need a 7.3 diesel even though I would love to have one... Decided what you are going to do with the truck and then we can give you some good ideas as to what you should do with the engine.
on
Well.. getting 400hp from a 302 is going to involve a lot of high rpms so gas milage will suck when you're using all those ponies, a larger motor produces a wider powerband at lower rpms so it makes a better truck motor and can get better milge in some situations. But it depends what you want, if this is going to be a 2wd street truck a built 302 with lots of gearing can work real well and still get decent milage when you're not honking on it. But if it's mud and big tires you want to play with, get a 351, stroke it out to 400 cubic inches, mount some big heads on it and let the fun begin.
