Washington Chapter Washington Chapter
Join Chapter, Leader: Tim Young
Like an airplane without wings...
Old Nov 9, 2009 | 01:57 PM
SpringerPop's Avatar
SpringerPop
Do the generators run at 1800 or 3600, or at something else completely different?
Given the huge gear ratio, are the transmissions "screamers" when you're up there? Ear protection required?
Pop
Old Nov 9, 2009 | 02:23 PM
Snowbunny's Avatar
Snowbunny
The Rotor (the part that looks like a prop) spins at 14.4 RPM and the Gearbox steps it up to 1,200 RPM for the Generator, so that's what,,, an 84:1 ratio.
And yeah, it's like standing behind a jet engine if you're uptower and it's running, but from the ground, it's more of a distant whine. The most you hear from the ground is the wind passing over the blades and the relays banging open and closed.
There aren't too many reasons to be uptower while she's running, except to check a small number of items, and even then, it's not at full production. The risk of getting tangled up in the drive-shafts is way too high. Nobody survives those encounters, so they kinda frown on them.
Old Nov 9, 2009 | 02:53 PM
Snowbunny's Avatar
Snowbunny
OMG!!! Look what I just found!!! This was one of her last climbs!! She's such a dirty little piggy!!! Ha! Ha!! Ha!!!
I love you, Honey!!! Muah!!
Ha! Ha!! Ha!!! And she's even wearing her FTE Shirt!! Good Girl!!
Old Nov 9, 2009 | 05:04 PM
SpringerPop
This HAD to be "makeup" for photo-taking time!
I get dirty a LOT, and nobody gets their face that dirty without also getting their hands. shirt, and harness filthy!
And those pinky fingernails haven't got a hint of grime under 'em!
Busted!!!
Pop
Dirt Detective
Old Nov 9, 2009 | 05:07 PM
SpringerPop
How is the output sync'd to the grid? Are the generators AC and mechanically sync'd, or DC and then inverted and electronically phase-locked to the grid?
If it's 1200 rpm, I suspect it's AC.
Pop
Old Nov 9, 2009 | 05:34 PM
Snowbunny's Avatar
Snowbunny
Yes, AC is correct.
All the power is inductive, so we run it through the DSTATCOM ~ Distribution Static Compensator ~ Which measures the incoming inductance and then adds capacitance to correct any reactive power blips, and keep the power factor in check. This also helps maintain a stable voltage as well. Needless to say, the Power Administration dearly loves us for that and spanks us hard if we don't get it right!!
jhooch
May 22, 2014 01:35 PM
58AZF100
Apr 1, 2012 10:30 PM
PwerStroke99
Idaho Chapter
Jan 10, 2011 05:20 PM
turbohunter
Nov 20, 2010 07:58 PM
a_Pink_Bunny
Jun 9, 2002 11:21 PM
