Bench seat in the front of an 05 excursion
Has anyone installed a bench seat in the front of their excursion???? i want to do it because i dont need the center console and want to have room for more people.... pictures would be great and install tips and also what truck should i take it out of to fit right in!
on
This has been done and documented, just search for the threads.
I some how don't think the full bench came in the leather, or is VERY rare. The split 40/20/40 does tho. The 20 is the flip down seat console. You can put this in with your original seats with a few mods.(the flip down arm rests will have to be removed, as with the mounting studs ground off)
Most any from the 00-04 will fit and color match, upto 08 should fit but not color match.
(reg cab and the 4 door cab only- as the extend cab have front seat belts in the seat if you go the full seat set replacement.) It is harder to find just the 20 seat separate, but some wreckers have them, or you could go the whole set up for more and not worry about having to grind off the arm rests.
I ordered my 20 seat on friday and should have it in later this week for a sat install. I have the cloth, so I figure I will be grinding off the original arm rests and finding an upholstery part to cover the hole left in the seat.(hopefully) Here is the link that I used to find one. Car-Part.com--Used Auto Parts Market
Good luck.
Good luck.
on
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Stewart
