Whether the price is good or not, seems that that the above mentioned is the only place that you have found. Usually a tire shop that also deals in truck tires can do the I-beam bends. It is just unusual for an I-beam to be bent.
Is it? ok, well I have only ever had one other I-beam ford aligned but it was hit and definitly needed a bend. I guess I will take it in and see. No I have not had the toe adjusted.
