02 250 parts, 03 yamaha raptor 660 parts, 04 gsxr rotors
I have a bunch of parts here for various vehicles. All prices are best offer so don't be shy to negotiate. pm or text me with any questions or if you want to see any pics. 407 489 7791 all items are in the clermont orlando florida area
1. yamaha raptor 660 case halves. matching set. stock all bearrings included. the timing chain guide is broke off. needs small repair. 100 or best offer
2. yamaha raptor 660 right side cluch cover. stock. has the oil line connection stripped out. needs to be heilie coiled and repaired. 20 or best offer
3. yamaha raptor 660 foot pegs both sides. good condition. 20 or best offer
4. yamaha raptor 660 right side heel guard with metal frame. tabs bent but still in working condition. 30 or best offer
5. yamaha raptor 660 stock rear axle. good condition. replaced on bike with extended axle. not bent or damaged. 75 or best offer SOLD
6. yamaha raptor 660 stock brake lines. front lines from top all the way to the calipers. all were working when removed for extended lines. 20 or best offer
7. yamaha raptor 660 stock front and rear bumpers. slight damage and bent. still work and mount fine. 20 or best offer. SOLD
8. honda 250 fourtrax jug, head and valve cover. all covers included except one of the valve covers. no bolts includes piston. needs to be bored as jug is
scored up to the exhaust port. head looks in great shape. 250 or best offer.
9. yamaha raptor 660 exhaust cover front. new never used. 5 bucks SOLD
10. yamaha warrior stock chain guard in good condition. 10 bucks
11. yamaha raptor 660 stock a arms. upper left and both lowers. make an offer on one or all that are left. sold the upper right. UPPER LEFT SOLD
12. yamaha warrior exhaust heat sheild. 10 bucks
13. 2002 ford f 250 super duty 4 wheel drive brake lines. front and rear. all stock in good condition. removed for installing exended lines. 40 or best offer
14. 2002 ford f 250 super duty 4 wheel drive front leaf springs. stock in great condition. removed to install lift. 150 or best offer.
15. 2002 ford f 250 stock air breather and air box. all in good condition. removed to install k and n. full system. 50 or best offer.
16. procomp latter bars/ traction bars for a 2004 f 150 these will fit dodge laramie, toyota tundra mark lt and others please check fitment. the procomp part numbers are 72500b for the traction bars and 72096b for the mounting kit. all brand new in the box. Includes everything that comes in kit. 250 or best offer.
17. 2002 ford f 250 super duty 4 wheel drive stock brand new fog lights and mounts. removed before purchase brand new to install bull bar and fog lamps. 60 or best offer SOLD
18. hiper cf-1 carbon fiber bead lock rims. for front single bead lock. does not fit yamaha. i do not know what the will fit but i can measure whatever you need to
ensure fitment. in good condition. includes all rubber gaskets and beadlocks. is missing one bolt. both sides. includes two rims. 300 or best offer.
19. yamaha raptor 660 stock front shocks. no leaks. good condition. removed to install new elka shocks. 70 or best offer. SOLD
20. 2002 f-250 super duty 4 wheel drive stock rear leaf spring without bottom spring and center pin
21. 2004 suzuki gsxr 750 chain $15
22. 2004 suzuki gsxr 750 front rotors $80
23. 2002 ford f 250 wheel hub assembly includes studs and nuts. 50 or best offer.
24. raptor 660 wheel hubs both sides
25. raptor 660 wiring harness
26. raptor 660 lower a arms second set
27. raptor 660 dash black
28. raptor 660 on off switch with wiring
29. raptor 660 brake calipers front and brake discs
428HIGHBOY
09-17-2007 08:03 PM
