E-350 6.0 PSD 2005 Turn Hazard Flasher Location
10-22-2009, 04:49 PM
Can anyone tell me where did Ford stick the turn signal / hazard flasher?
What do I have to do to find and change it?
Thanks
10-22-2009, 10:34 PM
on
If you're referring to the flasher relay...you should be able to hear the bi-metal sound and trace down to sound.
10-23-2009, 07:12 AM
on
flasher
on mitchel on demand 5, it says the electronic flasher relay is behind the left side off the dash. a white/red, light blue and black wire go to the relay.
10-23-2009, 08:49 AM
Thanks to both of you...
The sound method is not applicable because it had failed.. but then this morning... it worked again!
Thanks again!
Kingstyle01
Electrical Systems/Wiring
04-22-2017 06:58 AM
Crash55
19
09-30-2015 08:12 AM
jph9475
1997 - 2003 F150
03-22-2013 09:16 AM
BuckHammer
15
03-11-2011 07:51 AM
BobL
02-06-2011 08:25 AM
2001 ,
2003 ,
2005 ,
change ,
changing ,
e350 ,
excursion ,
f150 ,
f250 ,
f350 ,
flasher ,
ford ,
hazard ,
location ,
signal ,
turn
