pick up coil gone bad, stuck valve, bent push rod?
10-26-2009, 12:47 PM
on
Ok, where's your ignition timing set? 10* BTDC w/ spout removed?
10-26-2009, 12:56 PM
on
Quote:
Originally Posted by
DLP Performance
Yes, I have done everything possible
10-26-2009, 01:06 PM
on
What were you doing when it started this? Was it gradual or sudden?
10-26-2009, 01:11 PM
on
You didn't accidentally fill up w/ E85 or something, did you?
Check the conector to the #3 injector , you can switch the #3 injector with another & see if the miss follows...
10-26-2009, 01:12 PM
on
it never has ran right sense i rebuilt it. I bought a truck for the motor and tranny and the other parts i needed to swap. ran fine when i bought it. i just tore it down and rebuilt it all. I only have 200 miles on it.
10-26-2009, 01:13 PM
on
lew52
never thought of that, i'll give that a try.
10-26-2009, 01:14 PM
on
DLP Performance
no we don't have that were i live, i run 93 in everything i own
on
That truck pulses 4 injectors at a time. 2 left, 2 right. Every other rotation.
10-26-2009, 01:18 PM
on
Was it running properly before you rebuilt it? Did you add a big cam or change the initial timing?
10-26-2009, 01:23 PM
on
DLP Performance
yeah it was fine, i drove it. no big cam, i put new timing set it. I do no for a fact that it's not off a tooth, we check 3 or 4 times rolling to motor over and the marks were lined up
10-26-2009, 01:29 PM
on
It's not backfiring or anything, just going lean & skipping? Here's a silly question, you don't have a couple plug wires crossed somewhere, do you?
10-26-2009, 01:30 PM
on
DLP Performance
no it don't backfire, and no wires are crossed
10-26-2009, 01:35 PM
on
what transmission is in it, what came in it, did you change the harness & ECM, etc.?
10-26-2009, 01:38 PM
on
it's 5 speed, and i had the truck the motor came out of, i used the harness and computer.
