pick up coil gone bad, stuck valve, bent push rod?
#214
alright i am getting closer!! got it all back together tonite and drove it. great power down the road. but it still seem to lack the power it has when cooler. it's a lot better than before, i mean a lot. since it was dark out i check the manifolds and they still get red, but not as bright as before. still has a little trouble starting after it's been sitting for a about 5 mins. but it's not as bad either. so with all that said, i put my fuel pressure gauge on it again tonite. i have 38 lbs with just the key on, then start it up i have 36 to 38 lbs. with vacuum off i get 42 to 44. plug the vacuum back in and rev it up goes up to about 40 and then drops a bit when you hold it there, but it doesn't dope that much. it really drops when i rev it and then let off the throttle. as soon as i let off the throttle it drops to about 30 to 32 lbs. so i am thinking i have and issue with my new fuel pump. it's something fuel related, has to be.
#215
You may also have a partially plugged up cat if you have one on there. It sounds like the vacuum may be a little low. Have you checked it with a vacuum gauge.
The fuel pump should put out about 95 Lbs PSI against a blocked head. The red manifolds does sound like the may be running a little lean. What color are your injectors?
#216
#217
#218
#219
but i think your right though on white injectors in a 460 too. there's a guy here at work has a tone of ford parts and we were talking i think there's purple, white and light blue.
#223
ok that's cool, let me know. like i said though, when i got the motor i have now before i rebuilt it, it had light blue, put another set of light blue one in off another 460, the van i took out awhile ago where light blue, and the truck i took the heads off of where light blue. so i don't know.
#224
ok that's cool, let me know. like i said though, when i got the motor i have now before i rebuilt it, it had light blue, put another set of light blue one in off another 460, the van i took out awhile ago where light blue, and the truck i took the heads off of where light blue. so i don't know. but yeah let me know
#225
something just doesn't seem right, the motor really doesn't have a shake to it, but the rest of the truck does. say looking at my seats and stuff while it's at idle, they shake a bit, kinda odd. but they way it runs when it's cool. just seems like something stupid that i am missing. just wouldn't think it's the injectors. i don't know
