Wheels for the F250?
Old 10-18-2009, 10:53 AM
CK3's Avatar
CK3
CK3 is offline
I just bought a set of 265/75-16 E-Rated, Bridgstone Duelers for the truck.. The more I look at it..I would like to ditch the hubcaps.
I was thinking about these..
Mickey Thompson Classic II 16x8 8-6.5 Bolt pattern 4" BS
16x8
8x6.5
4"BS
Whats the backspace on my stocker wheels? Anyone runnin them? I'm also worried if it will fit over the hub in the rear?
Thanks...
Old 10-18-2009, 11:28 AM
donniezyea's Avatar
donniezyea
donniezyea is offline
BFG and Bridgstone are 2 different tires, you have very good tires on that ford now!
BFG Duelers
I hear ya on gettin rid of the stock ford plastic covers, however you may have a problem if you do have a f-250 HD with the full float in the rear. I have heard alot about grinding the rim down to fit over fords rear axil. My f-250 does not have the full floating axil so i didnt have to worry. So good luck either way you got some sweet tires and the truck looks good too!
Old 10-18-2009, 11:39 AM
CK3's Avatar
CK3
CK3 is offline
Originally Posted by donniezyea
BFG and Bridgstone are 2 different tires, you have very good tires on that ford now! I hear ya on gettin rid of the stock ford plastic covers, however you may have a problem if you do have a f-250 HD with the full float in the rear. I have heard alot about grinding the rim down to fit over fords rear axil. My f-250 does not have the full floating axil so i didnt have to worry. So good luck either way you got some sweet tires and the truck looks good too!
Doh!.... I meant Bridgstones.. I just bought the BFG's last week for the Focus..Here are some pics of the rear.. I'm not familiar with the F250 axles.
Old 10-18-2009, 11:43 AM
CK3's Avatar
CK3
CK3 is offline
It just dawned on me.. Your talkin about the hub under the hubcap.. Yes. I have the floating axles.
acf6
1999 to 2016 Super Duty
01-15-2012 11:43 PM
SuperDuty93
13
07-08-2011 05:53 PM
akinswi
2004 - 2008 F150
19
12-10-2010 04:40 PM
jdecker88
26
02-28-2010 11:44 AM
Quick Reply: Wheels for the F250?
