Best Ball Joints ???
I got 182K out of the originals. I bought the Moog greasables a couple of months ago and put them in (both sides, upper and lower). They are broken in now (186K) and I love them. I grease them every oil change. My upper ball joints came with the 90* zerk in the box with the joint. I had to grind the slightest bit off for them to fit in the yoke so that they wouldn't rub, but other than that everything fit great. I considered XRF, but could find very little feedback so I went with Moog like so many others. I hope to match the originals and get 180K out of them...
You may have noticed a plug that should have also came. What you do, is install the knuckle, grease the upper joint, and removed the grease fitting, and install the plug in its place. (Before you put the axleshaft back in place.) Unless your the religious greasing type. I never really grease mine, and they last long enough haha.
I think that has to do with driving conditions. We have (4) 99-03 super duties at out shop. All of them diesels. Two of them with snow plows. Other then one of the trucks with a plow, all of outs went above 150k. Mine werent somewere untill around 175k. I put OEM ones back in mine and the early 99. Second choice. Moogs.
Like I said, I think it has alot to do with how the truck is used. I know the one 02, had alot of ball joint trouble, that the dealer had been fixing under warrenty pretty early. But I think its because that truck had a bad set, and they would replace individual ball joints at a time. Not even both on one side.
How to ID Napa Premium?
At Napa, they don't specify premium or describe the construction of their ball joints Just say the Ore expensive ones are better
Any body have a part number or other way to identify the premium ball joints that have the Kevlar pad with grease grooves?
The ones they showed me are 260-1248 upper and 260-1395 lower. It does say made in Taiwan all over
Any tips? I know this is an old thread but it's a timeless topic.
