please help
Old 12-26-2009, 04:18 PM
rpdwelding's Avatar
rpdwelding
rpdwelding is offline
please help
Ok here goes. I have a 99 7.3 powerstroke. Last year the fuse panel in truck got soaked. I dried it out. When I would try to start, it would not crank and would blow the #30 fuse that powers the idm. I replaced fuse panel hoping it would fix the problem. No good. Next I got a matching pcm and idm from a 2000 7.3 crashed truck. the wait to start lights came on but still would not crank. I jumped the starter selanoid and it started. ran for about 45 seconds and shut off. now the wait to start light is not coming on and it is popping the fuse when you turn the ignition switch to on. dont want to spend any more money. Argh!!
Old 12-26-2009, 04:24 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Did you check the fuel bowl heater?try unplugging it and see if it still blows the fuse
Old 12-26-2009, 04:36 PM
rpdwelding's Avatar
rpdwelding
Thanks,I will check that tomorrow. What would cause the truck not to even crank when you turn the key?
Old 12-26-2009, 04:41 PM
andrewc53's Avatar
andrewc53
andrewc53 is offline
# 30 blows when fuel bowl heater is shorted, and truck won't turn over without that fuse. A Curtis
Old 12-26-2009, 04:43 PM
Orezona's Avatar
Orezona
Orezona is offline
If the fuel bowl heater is blowing a fuse, your engine will crank but you won't hear the fuel pump run when you turn the key to on before cranking.
Old 12-26-2009, 04:53 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Batteries may be dead by now.
Just postulatin'......
Old 12-27-2009, 05:17 AM
andrewc53's Avatar
andrewc53
Sorry my bad. A Curtis
Old 12-27-2009, 10:46 PM
rpdwelding's Avatar
rpdwelding
Unplugged fuel bowl heater. Does not blow fuse now. still truck wont even crank, also no wait to start light, could the fuel bowl heater have blown idm somehow, or is it something else?
Old 12-28-2009, 07:19 AM
CPUNeck's Avatar
CPUNeck
CPUNeck is offline
"wont even crank" meaning the starter does not engage, or the engine spins but fails to start? Have you checked the harness that connects with the 10mm bolt over the driver side valvecover? Turn the ignition on, then hop out and wiggle right at that harness. Listen for fuel pump, or other noisy items under the hood. If you suddenly hear stuff, you have a short in that harness (very common.) Just for laughs, if you have a Digital Multi Meter (DMM) that has the ability to test a diode (most do) find the PCM diode (it's black with the diode symbol on it) and test that it is working. After rereading your post, found that you've replaced both the PCM and IDM what lead you to that conclusion this early?
Old 12-28-2009, 08:18 PM
rpdwelding's Avatar
rpdwelding
Does not crank the starter at all. Got in today and hooked battery up, Wait to stat light is on and everything sounds like it is turning on under hood. Still wont crank when I turn the key? Gonna test solenoids tomorrow. After no progress after replacing fuse box, I remembered IDM also got very wet so I thought I would try this route. A totaled truck came in at the body shop next store , owner said take what I want so I took the computers to replace mine. Now im here.Thanks
Old 12-28-2009, 09:13 PM
Orezona's Avatar
Orezona
Orezona is offline
Pull your Batts, trickle charge them, put them back in and attempt to start. Then post results.
Old 12-30-2009, 11:13 PM
rpdwelding's Avatar
rpdwelding
Checked starter solenoid , NO GOOD. replaced and it cranked slow. Recharged batts and it started. Thanks so much for all the tips. allt he bits and pieces realy helped me check all types of things I normally would not have.. Thanks again
Old 12-31-2009, 02:46 PM
8tsixt's Avatar
8tsixt
8tsixt is offline
Congrats on getting her going again. Thanks for posting the final outcome.
edroe
26
08-15-2011 10:37 PM
hopp
31
06-29-2011 09:07 PM
joshinthe586
03-26-2011 10:47 AM
bcmchong
13
12-27-2010 02:20 PM
bcmchong
12-26-2010 04:05 AM
Quick Reply: please help
