Interior door and window handles removal ?
Okay , I got the door hinge pins out and the hinges removed from jam . I started to remove all of the hardware from the doors . The handles are held on different than I expected I can't find any spring clips to remove . How are they held on and how do I remove them ? One door handle has a metal cover and the other has what looks like vinyl between it and door . I can push the vinyl one back but not the metal . I am new to working on fords of this year , 1951 F-1 . Worked on brand X to long I guess . Thanks ahead for any help . JIM P.S. I tried the search but it would not work , I don't think it was F T E , I think it was my cheap hand me down P.C
Picture:
The pin is tapered a dash so if you tap it and it doesn't budge, try the other end.
Also, the handle has 4 holes in it so you can mount the handle in different positions on the shaft. If you can't find the pin in one batch, look in the other - 90 degrees off.
Be very careful when tapping it not to hit it hard enough to cause it to rotate and brake the spring on the inside mechanism.
Picture:
Attachment 18317
Attachment 18317
WVVan
19
06-16-2016 12:16 PM
Marty Smilt
10-09-2010 12:23 PM
