fun with a 302
Old 10-17-2009, 10:38 AM
410
410 is offline
410 is starting off with a positive reputation.
fun with a 302
93 f150 302 e4od low miles ( under 15,000 actual ) ive been over this before but ive got a short attention span i want to put a cam headers and a set of e7 heads on the engine the heads are off a 89 f250 351 i would like to match the cam as close as i can to the heads and what would be involved in fiting the heads on the 302 i know the head bolts are differant i think
Old 10-17-2009, 11:07 AM
1966Tbird's Avatar
1966Tbird
1966Tbird is offline
1966Tbird is starting off with a positive reputation.
your e7 heads are what should be on your 5.0 anyway putting the 351 heads on is just going to be a pain in the *** since you have to either use special bolts or special washers since a 351 uses bigger head bolts than a 302
are you trying to keep your fuel injection? and i hate e7s i ran a ported set of e7s for a while and have ran 160cc systemax heads and currently have 190cc trickflow heads on my 302, i'd bet with just the head and cam change i doubled the h/p from stock
if you are hardpressed at using those e7 351 heads then edelbrock makes headbolt shims so you can use the stock head bolts for the 302 or you can make the bolt holes in the 302 the same size as the 351 which is what you do when you have a lot of forced induction since the bigger bolts hold the head down better. you will want to change out the springs on your head to match the cam you get stock springs are only good for like .500 lift which is nothing right now i am running .598 lift on my motor, be sure to check piston valve clearance when you go over like .530 lift
Old 10-17-2009, 09:11 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
You already have E7 heads on your 5.0 so don't waste your time taking them off unless you got GT40's or something better to replace them.
There are only a few cams that will work with the EFI system you have.. one of them is the Comp cam in my sig.
Old 10-18-2009, 08:07 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
If those heads only have 15k miles on them, I would leave them on the truck unless you have GT40s like was previously stated. They should be E7s anyway.
drileybond
26
01-15-2012 12:38 AM
nintey4f150
07-20-2010 05:56 PM
gamudslinger88
01-14-2008 11:04 AM
jpdmoe
09-04-2004 04:50 PM
sargroup5
05-26-2001 10:24 PM
Quick Reply: fun with a 302
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
