03 Expy - rust on lower door folds
Hi,
I have an '03 and I just noticed that I have rust at the bottom of the front doors where the sheet metal folds. I never noticed it because on the '03 there is a gasket attached to the bottom of the door panel that covered the seam. Has anyone fixed this and is there a good method that will work to stop the rust from getting worse?
Other than this the Expy is in great shape with no body rust or major problems so far (100k miles). Other minor problems so far:
- Blower motor resistor replaced due to no fan on position 1 of switch
- Repaired IWE vacuum line which had a hole worn in it (rubbed against tranny dip stick tube). The hubs would rattle when accelerating.
- Need to look into rear HVAC blend door since I can only get air from the roof mounted vents and it won't switch to the floor vents. Not much of an issue though.
Any suggestions to deal with the rust would be appreciated.
Thanks
Thanks
That problem was supposed to have been resolved for 2002+ model years. Here is the TSB anyway for the earlier years.
04-18-11***BODY-CORROSION AT BOTTOM OF DOOR OR TAILGATE HEM FLANGE - REPAIR PROCEDURE
I had the same problem on a bunch of vehicles I had. I found some stuff called Bill Hirsch Miracle Paint. It completely takes over the rust and prevents it from coming back. I tried it on my other car, which was a very rusty Oldsmobile and it stopped the rust immediately. The rust never came back. It isn't that cheap but it still cost less than having the dealer fix it. The paint will work as long as there is the metal it is being applied to it still strong.
Here is the website I found the paint on:
-Hirsch Automotive Products
Here is the paint:
Miracle Paint Rust Killer
Here is the paint:
Mikec35
1999 to 2016 Super Duty
03-25-2015 01:48 PM
jvmcc
05-31-2014 04:04 PM
