How does your PSD 'crank'?
Old Oct 15, 2009 | 08:28 PM
bdrummonds's Avatar
bdrummonds
Originally Posted by danskool
Big rig. I thought the same.. Mine varies on time it takes to "GO"
Turn on key.
I don't pay attention to the light. But listen for the vacuum pump fart. Soon as it fart. Turn key.
Crank, crank, crank.
Varoom. <- more like a kaplow? Nah. Wierd can't spell it.
OR somthimes i get a crank,crank,crank,crank,crank,crank.
Varoom.
It don't matter what temperature, it varies. No Go peddle, Ever.
My dads is more consistent. Crank crank crank. Varoom.
I think the words you are looking for are "Barks like a big dog"
Old Oct 15, 2009 | 08:47 PM
SunBum's Avatar
SunBum
Thanks again everyone for the input.
I'll check on the things you all suggest and stay off the pedal.
...I like the sound too!
Old Oct 15, 2009 | 09:03 PM
Franko72's Avatar
Franko72
Molon Labe
After cleaning all four batt terminals last weekend, mine cranks alot faster than it used to, I also changed the solenoid and it gave the starter a whole new "tinny" sound ???
Old Oct 15, 2009 | 09:34 PM
Pocket's Avatar
Pocket
By the way, something I forgot to mention...
Hitting the accelerator pedal while cranking does nothing. The injectors will not be commanded to fire until proper oil pressure is reached. So until that happens, injectors stay turned off even if your foot is on the pedal.
Old Oct 15, 2009 | 10:04 PM
rbaker6336's Avatar
rbaker6336
May not supose to but mine absolutely would not start without the pedal being on the floor.then wuld only idle If i let off it would die
Old Oct 16, 2009 | 01:56 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by indyF-350psd
my 02 cranks and fires up fast but my father in law's 00 cranks a little slower. i think its the temperment of the truck personally. jmo...........
'02, '03 MY trucks came with a gear-reduction starter, less teeth on the starter and much higher torque. It was implemented to make starts much easier with less crank time. Once my starter goes, I'm getting myself one off ebay or somewhere local...
Old Oct 16, 2009 | 06:43 AM
Visseroth's Avatar
Visseroth
Well i didn't read through all the posts but my truck after getting new batteries and when cold (40 to 50F outside) will turn over about 3 or 4 times then WAM! she's alive but she turns over pretty fast since I got the new batteries which allows it to build pressure faster.
Old Oct 20, 2009 | 11:46 PM
speedyvuu's Avatar
speedyvuu
Quoting from Texas Outlaw, mine is more of a claaack claaack claaack claaack vroom
Old Oct 21, 2009 | 12:01 AM
Visseroth's Avatar
Visseroth
Found out over the weekend that if you roll these things and pop the clutch they don't ask questions or make much noise other then "CHERP! BLAP BLAP BLAP BLAP BLAP, VROOOOOM"
Old Oct 21, 2009 | 02:35 AM
twags6's Avatar
twags6
So you can start em that way? I always wondered....
Old Oct 21, 2009 | 05:58 AM
Visseroth's Avatar
Visseroth
Yeppers, I wondered as well and was in a drive way going down hill and thought I'd screw around a bit, turned the key on, started rolling, popped the clutch and WAM! she's running. Just had a little cherp from the tires is all, just remember when you do it use 2nd gear, seems to work best that way in most manuals.
ChrisCarter
Apr 5, 2013 05:20 PM
John7894
176
Oct 18, 2008 01:19 PM
RapidRuss
184
Jul 30, 2004 06:10 PM
BobbyL
34
May 17, 2003 06:17 PM
