Squeaking/Chirping Front End
Old Oct 13, 2009 | 10:30 PM
smythcounty's Avatar
smythcounty
As I drive down the road I can hear a noise coming from the vehicle. For you country folks it sounds like driving by a pond during the summer and hearing the frogs croak.. I couldn't figure it out so today I put it on jack stands and put it in drive. It didn't make the noise. I spun the front tires as hard as I could with my hands and didn't hear it. However, when I put it in 4wd and the front wheel starts spinning the noise appears. I crawled under and cannot figure out where it is coming from. I lubed and sprayed everything that even looked like it could be lubed and it still makes the sound. I'm thinking something in the front axle.....any ideas?
Old Oct 14, 2009 | 10:03 AM
g_k50's Avatar
g_k50
check lube in differential
Old Oct 14, 2009 | 10:48 PM
killit's Avatar
killit
you need to pull your wheel bearings, pack and/or replace. I'd replace them, its fairly inexpensive and easy to do. I'm pretty sure you may have one going out and if not addressed soon it may lock up on you while driving, ruin your spindle, etc..
lin 842
1978 - 1996 Big Bronco
Sep 2, 2018 09:31 PM
El_Coqui
Aug 3, 2014 10:40 PM
Cornell1
Jul 1, 2013 07:55 PM
wezol5484
Mar 27, 2012 09:59 AM
cperdue3
May 23, 2005 01:24 PM
