1997 Ford Explore xlt v8 5.0
Old 10-08-2009, 08:09 PM
needalittlehelp's Avatar
needalittlehelp
needalittlehelp is offline
Currently geting code p1401 manufacture control, auxiliary emissions control. any suggestions on where to start. thanks.
Old 10-09-2009, 04:00 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Check your DPFE and the egr passageways for coking/soot, clean.
Old 10-09-2009, 06:22 AM
shorod's Avatar
shorod
shorod is offline
As Aquananaut20 suggested, per the factory service manual P1401 indicates that Self-Test has detected DPFEGR circuit input above the maximum.
Possible causes:
-- DPFEGR open.
-- DPFEGR shorted to VREF or PWR.
-- VREF shorted to PWR.
-- SIG RTN open.
-- Damaged D.P.F. EGR sensor.
-- Damaged PCM.
The DPFE is a common problem with this vintage of Fords. Seems like a good place to start.
-Rod
Old 10-09-2009, 07:48 AM
needalittlehelp
Thank you, i will start with the replaceing the DPFE and cleaning out the egr passageways and let you know. I appreciate the advice.
Old 10-10-2009, 02:39 PM
needalittlehelp
97 ford explored xlt v8
So i changed the egr valve, DPFE and vacuum sensor. now the check engine light is gone but my abs light came up. not sure if related but breaks are working fine. any ideas of sensors i can check for this.
thank you for your time and help.
Old 10-10-2009, 03:14 PM
aquanaut20's Avatar
aquanaut20
ok I would start here,
all you have to do is go to the rear end of the truck and place your hand on top of the center of the rear end you will see a wire connector there is a 10 mm or a 13 mm bolt on top remove the bolt and pull the sensor out this is called a abs sensor, clean and/or replace.
Old 10-14-2009, 07:49 AM
needalittlehelp
CEL came back and still getting code 1401
Changed the egr valve, DPFE and vacuum sensor, light went off for four days and now is back on. Any ideas? I checked all the wires and connections an they all appear in good shape.
Thank you for your time and help.
Old 10-14-2009, 08:50 AM
aquanaut20's Avatar
aquanaut20
Need to scan codes again, take note of the Freeze Frame info as well.
njstevens
10-01-2021 09:41 PM
mrwrench
10-19-2009 01:25 PM
macguyver
01-15-2003 10:25 AM
unreng
Aftermarket Products
12-05-2002 09:34 PM
Quick Reply: 1997 Ford Explore xlt v8 5.0
