Codes 332 and 334.
Old Oct 12, 2009 | 02:32 PM
rootbeerford's Avatar
rootbeerford
Codes 332 and 334.
<TABLE style="BORDER-BOTTOM-STYLE: none; BORDER-RIGHT-STYLE: none; WIDTH: 452.5pt; BORDER-COLLAPSE: collapse; BORDER-TOP-STYLE: none; BORDER-LEFT-STYLE: none; mso-border-alt: solid windowtext .5pt; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=1 cellSpacing=0 cellPadding=0 width=504><TBODY><TR style="mso-yfti-irow: 67"><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 35.7pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=41>332
</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.55pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=48>
</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 37.8pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=47>
X
</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 26.95pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=36>
X
</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 513.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=545>EGR valve opening not detected.
</TD></TR><TR style="mso-yfti-irow: 68"><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 35.7pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=41>334
X
X
X
</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 513.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=545>DPFE or EVP circuit above the closed limit of 0.67 volts.
</TD></TR></TBODY></TABLE>332 - EGR valve opening not detected
334 - DPFE or EVP circuit above the closed limit of 0.67 volts
Ok, now what?
If its relevant my MIL lights up the first time the truck experiences no load in gear (coasting) after startup.
Old Oct 12, 2009 | 03:19 PM
rla2005's Avatar
rla2005
Use a hand held vacuum pump/gauge to apply some vacuum directly to the EGR valve to verify the EGR valve moves. If it does verify the vacuum circuit leading to the EGR is in good condition. Sometimes the EVR valve is no longer functioning (stuck closed), but still remains electrically connected. It would also be a wise idea to put a meter on the EGR position sensor to make sure it is reading correctly too. If you have a later model truck with a DPFE instead of the EVP sensor, they are well known to be borderline even when new. Ford has released updated versions many times to lessen false EGR related codes.
Code 334 indicates the EGR valve is probably not closing all the way due to build-up and/or faulty diaphragm. Remove the EGR and clean it.
bismic
May 21, 2017 07:26 PM
bismic
Feb 24, 2017 09:06 PM
bismic
Nov 23, 2016 07:43 AM
gareth12
Aug 10, 2012 09:28 AM
