Electric fuel pump relay location
#76
Circuit 787 bypass all other relays, switches and fuses and sends power right to the fuel pump. The fuel pump must run with power on this wire after the fuse link "R".
#79
I jumped the oil pressure kill switch plug and tested for power at the tank. (Which was NOT easy to get to!) The plug back there initially looks round, but if you look inside you'll see that it is actually heart shaped with three sockets. Looking at it upside down, The socket on my lower left had 1 to 8 volts, and jumped around a lot, constantly in fact. The socket on top had .01 volt and the socket on my lower right had .02 volt. I figure that one live socket is for the fuel gauge.
So do we have positive proof that the fuel pump is toast? I just can't believe that. I've been working on cars and trucks since the late-70s and I have NEVER seen an electric fuel pump just quit. They always make a big production out of it first, with lot's of noise, whining, etc. I mean seriously, after all of this troubleshooting, it can't be just the fuel pump can it?
#80
#81
No, like I said, it looks round, but when you look inside it is actually heart shaped. It has three sockets. I think we have one for the fuel gauge, and one for the positive side of the pump, and one that may be a ground? I removed and replaced the plug several times the first time I was back there to clean up the connection, what should I do next?
I have a little room to work above the fuel tank. If I do need to replace the fuel pump, will the assembly come out the top without too much trouble or is it some long, giant contraption that has to pull straight up for two feet, requiring me to drop the tank? If that's the case this might have to get drug over to a storage yard and sit for another year cause this move needs to go forward!
#82
#84
#85
Yeah, I was already thinking that, especially since I apparently have some oddball set-up with a unique plug that I may not be able to find a replacement for. I forgot how Ford likes to change stuff every six months. It's one of the reasons why I've always had a love/hate relationship with Fords. One could say that it's because they're always improving things, while others will say it's because they didn't get it right the first time. Do I sound a little frustrated?
I'm just plain flat out of time. I have a lot of stuff and other cars/trucks that need to be moved too.
I don't know if it's going to be a week, a month, or a year before I get back to this, but I will report back when I have new news.
Thanks big time for all of your help!
Regards,
Eric
Regards,
Eric
#86
The reason why I never updated this thread as to the cause of my trouble is because I just gave up on Uncle3. I am however moving now so this rig HAS to run now. So here we go. We are finally going to figure this out, even if it kills us!
The very first thing I suspected when this trouble first began was that device that kills the fuel pressure if and when the vehicle is in an accident. Where is this thing located? Is it part of the relay? Is it nearby? What does it look like? How can I temporarily bypass it so that I can properly diagnose the cause of my lack of electrical power to my fuel pump?
danny1335
16
10-04-2016 01:56 PM
tekrsq
10-28-2011 04:47 PM
krs_med
07-12-2011 11:42 AM
