460 to 7.3 idi swap
Old 10-10-2009, 09:21 AM
ahmincha's Avatar
ahmincha
ahmincha is offline
460 to 7.3 idi swap
Hi everyone I have a 89 f450 with the 460. I looking at a 90 f350 with a 7.3 idi complete running truck the 460 is bad so i was thinking of converting to diesel. My cab is also rotted out and the new truck cab is in good shape so i will be putting the 90 cab on the 89 450. what i would like to know what issues i will have will the diesel bolt in (are the k frames the same) any surprises i should be aware of any help will be appreciated thanks
Old 10-17-2009, 09:01 AM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
first i dont know where you are but are you going to be able to register and drive the truck after this swap? worth looking into. i am not sure if the fames are the same what i would do is to look at them and take mesurments, with enough work anything can be done. my guess and it is just that a guess is that the motor mounts and trans mounts will be different, and the spring rates too....you might need a new fuel tank and lines and pump and filter.....most thing you should be able to get off the 90 truck. again just look at it and take a lot of mesurments first. good luck!
yz450guy
03-30-2017 08:55 AM
skoto1
General Diesel Discussion
03-09-2016 08:21 PM
Vin Man
07-26-2014 03:41 PM
Xpebrian1
05-14-2013 10:49 PM
Shwan_89HD
15
01-24-2012 09:43 PM
Quick Reply: 460 to 7.3 idi swap
