2005 4.6 2 valve in a 68 F100 - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-15-2010, 04:29 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
Trac-lok was an extra cost option on the CVPI and of all the ones I have worked on and driven, I have only seen one with it.
It's 3.55 too.
  #32
Old 03-19-2013, 11:02 PM
Shoestring's Avatar
Shoestring
Shoestring is offline
Shoestring is starting off with a positive reputation.
Wow it has been a while since I have checked on this thread. I had life catch up with me but here lately have been making some headway on the truck. I am still cussing wires but confident that the solution will present itself. One problem has been solved and that was PATS. I have a computer from a police cruiser so PATS is disabled. I did get the rear axle installed from a 98 Ford Exploder, disk brakes 4.10 gears with track lock. Should be fun to drive. I will have to tub the rear fender wells to allow more room for the narrower axle. Changed out spark plugs and have a 12 foot wiring harness laid out over the garage. Hopefully this summer we will see her come to life. Romak let me know if you are still around and have any suggestions.
SS
  #33
Old 05-06-2013, 09:53 AM
SkinnyPedal's Avatar
SkinnyPedal
SkinnyPedal is offline
SkinnyPedal is starting off with a positive reputation.
Doing the same in a 77 F100. Subcribed
  #34
Old 08-04-2013, 02:21 PM
Shoestring's Avatar
Shoestring
Have you guys seen or heard of someone modifying old gas tanks to be able to use a newer sending unit? I am doing my 70s mustang gas tank install and will be running fuel lines soon. I am puzzled at the best way to modify the top of the older tanks since they have the curved surfaces. I will have to cut a large hole in the top but then have to flatten out the curved top. I have seen one use a simple idea of a C clamp and a flat piece of steel to mash the surface flat. I wonder if there is a way to use a shim or something. Just thoughts.
  #35
Old 07-08-2018, 06:11 PM
dwil's Avatar
dwil
dwil is offline
dwil is starting off with a positive reputation.
Did you ever figure this one out?
  #36
Old 07-08-2018, 06:24 PM
dynamic's Avatar
dynamic
dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
  #37
Old 07-08-2018, 08:49 PM
dwil's Avatar
dwil
dwil is offline
Originally Posted by dynamic View Post
Perfect! I have the old mustang tank already in my bump. I'll go looking for a 2000 Mustang tank now...
Tony79f100
Engine Swaps
10-19-2016 09:03 PM
Jebchief
28
04-03-2016 08:26 AM
50SICKS
12-06-2013 10:24 AM
Boston113
1997 - 2003 F150
02-17-2013 12:19 PM
GotFord83
49
02-04-2013 01:37 PM
Quick Reply: 2005 4.6 2 valve in a 68 F100
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
