oil analysis opinions
just had my oil analysis done and the results are as follows; alum-2ppm,chrom-5ppm,copper-15ppm,iron-17ppm,lead-9ppm,tin-2ppm,silicone-13ppm,potassium-2ppm,sodium-9ppm,moly-13ppm. Physical prop;water-.glycol-nd,fuel-4.2ppm,tbn-8.7,nitration-2ppm,soot-.5ppm.Thanks for any input since this is my first one.I am using 15w40 sythn with 162500 miles on the motor.Roy
that is what the tech guy said but he was not entirely familure with the 7.3. Do you know where a good place to start to look as to where the fuel might come from?
cps, here's my UOA to compare, your numbers are a little different but it could be a number of things, rings, injector cup are just a couple that come to mind, take a look::Miles on unit 116,650. Miles on oil 9,650 WEAR METALS (PPM): Copper:5 Normal. Iron:18 Normal. Chromium:2 Normal. Aluminum:5 Normal. Lead:11 Normal. ADDITIVES(PPM) Molybdenum:301 Normal. Phosphorus:1446 Normal. Zinc:1547 Normal. Magnesium:739 Normal. Calcium:2468 Normal. Sodium:8 Normal. Potassium:1 Normal. CONTAMINANTS-Antifreeze%: 0% Normal. Fuel Dilution:N Normal. H2O%: .0 Normal. Silicon (ppm):5 Normal. OIL PROPERTIES-Viscosity CTS:10.71 SAE-ISO:30 Abnormal. Measures and Allowable-must not exceed100%>Sulfur:7 Normal. Oxidation:0 Normal. Nitration:5 Normal. Soot:0 Normal. Used 9000 Supreme 5w40 synthetic. Notes: Viscosity has decreased to an SEA 30 weight. Oil should be changed. Resample to establish trends. Ford F-250 diesel 7.3.
Here's 2 more to compare to..............................................
UOA 7.3 F250 @ 294,444 mi Rotellla T - Bob Is The Oil Guy
wr310rdr
19
06-03-2013 02:27 AM
Brian460
04-10-2005 07:39 AM
