Restoring 1949 Ford F3
#92
Try U and I wrecking in San Bernardino, I've found lots of stuff for my 1960 F100.
U & I Auto Wrecking in San Bernardino, CA | 1435 W Rialto Avenue, San Bernardino, CA
I spent the past week in the Fresno, CA, area on business and noticed a number of salvage yards that appeared to specialize in pickups and trucks. I am wondering if there is a salvage yard out there that might have the one-piece wheels that would fit my F3. The climate out there lets things last longer than ours in New England. Stu says they would be 1952 F250 wheels...anybody on the list from Southern California who would know of such a salvage yard? I will be spending the holidays east of LA in the San Bernadino area and could do some searching, say in Fontana, Riverside, Ontario, etc.
CarlH
1949 F3
1997 F150
CarlH
1949 F3
1997 F150
#93
Zeke,
You'll have a lot easier time finding a F-2 to F-6 fender than a decent F-1. I looked at your profile and saw you're in SD. I know there are big farm trucks out there. The couple times I've been there I've seen a few just driving through. You probably know where some are or knows someone who knows someone who has one sitting out back somewhere. You guys don't use the salt we do here so everything isn't eaten away it's here. Look for a larger F-5 or F-6, same fenders as the F-3.
If you want to spent the $$$ Northern Classic Trucks have brand new bottom halves for F-1, $550 a pair. The bottom halves of the '48-50 truck are pretty simple and don't take much to repair, I know, I have a set I brought back from the dead. They were bad but it's a flat metal.
#94
My flathead V8 has a Holley 2100 carburetor. Is that a standard carb for these trucks? I have tried two oil-bath aircleaners (both from earlier years) and neither one clamps to the top of the carb. The top rim of the carb is too small. The clamps in both cases look like they want a ring at the top of the carb. What's wrong?
CarlH
Bedford, MA
1949 F3
1997 F150
CarlH
Bedford, MA
1949 F3
1997 F150
The original carb will have Ford on the right side of the bowl and 7RT on the left. Called the 8RT when equipped with cable choke lever (and hand throttle lever, if so eqipped.
There is a truck airhorn (top carb casting) and a car airhorn. The truck airhorn has what appears to be a sideways V cast around it. The car airhorn is flat with rectangular recesses cast in.
You cannot use a car air cleaner on a truck airhorn. The car cleaner's clamp is flat to mate to the airhorn. The truck's clamp is shaped to fit over the sideways V on the truck airhorn.
I have many 7RT cores I can rebuild for you if desired, with or without the hand throttle lever and bracket.
<a href="http://s131.photobucket.com/albums/p313/1952henry/?action=view¤t=100_1296.jpg" target="_blank"><img src="http://i131.photobucket.com/albums/p313/1952henry/100_1296.jpg" border="0" alt="Photobucket"></a>
This is actually a late 38-40 V8-60 Holley 92. You will notice it has a car airhorn.
#96
#97
Fiberglass F3 fenders
www.rodnrace.com
they are a one piece fender, 300 each
anyone seen or heard of this place? Not for me but its the first F3 fiberglass fender repro that I have seen...
#98
Remove instrument cluster on 49 F3
I am about to remove my instrument panel for cleaning and rechroming the trim. Any advice? or tricks that I need to know? Do I disconnect all the wires from the gauges first?
My progress to date....chassis sand blasted and repainted, brakes re-done, new SS brake lines, wheels from Pato in CA re-painted, new 17.5 X 8 tires from Universal, engine re-built and mounted in chassis, driveshafts connected, cab re-mounted. Winter is closing in, so I am trying to do indoor things. Thanks to all for advice and encouragement.Should be on the road next summer. Photos when I figure out how to put them on the list.
Carl Hanson
1949 Ford F3 pickup
Carl Hanson
1949 Ford F3 pickup
#99
If you're trying to preserve the wiring harness the best thing to do is disconnect all the wires and pull all of the bulb sockets. If you aren't preserving the wiring harness and it's junk just cut the wires but save enough wire on the wires so you can see the color coding. Hopefully you have a shop manual, it has all the color coding toward the back. If you're buying a reproduction harness I would assume they will furnish a wiring diagram but it's still helpful to have the wire remnants connected to the dash terminals.
There's 3 nuts that hold the pod into the dash:
#100
#101
#102
#104
From experience, one thing to watch out for is the stud starting to spin when you try to loosen the nut holding the wire onto the back of the gage. I wrecked one gage that way by mistake. Bob, question, another reason I have to get a shop manual, Are the guts of the oil pressure gage and fuel gage the same as the temperature gage? The temperature gage has an off position opposite of the other two gages. I'm pretty sure the gage is different in so much as when it is powered up it swings in an opposite direction. I havent been able to find one to replace the one thats bad. Any ideas?
