69 T-Bird Frt Suspension Grapht to 60 F-100
Hay All –
Have a question that hopefully someone out there can shed some light on for me. I have a suspension from a 1969 T-bird that I was pondering graphing to my 60 F-100 truck frame.
Although the wheel base is practically the same as the 60 truck and the front suspension rails / housing of the T-Bird front end align almost perfectly to the 60s – the T-Bird suspension is designed in the shape of a Y – which means – although the front suspension of the T-Bird aligns with the original 60 suspension – it starts to extend outside the 60’s frame rails as much as ¾ " on both sides. I was thinking I could weld channel stock to the outer sides of the 60’s frame rails – weld that to the T-Birds frame – then box it in all around with steel plating.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I’ve never taken on such a task as this – so I am having a hard time making that first cut into the 60’s frame – to cut away the original front portion. Has anyone out there graphed a different suspension to a truck or car frame – other then the usual Volarie and Mustang II frontends. If so - what should I watch out for - The benefits of doing this are great…. 10 in front disk brakes – IFS – power steering. I was planning on putting a 429 CJ into the stock F-100 front end and was concerned it would be way to much for the stock suspension to handle – that’s when I remembered the 69 T-Bird sitting out back and thought that perhaps I could use that front end – seeing that it has a 429 Thunderjet already in it. so the CJ should fit right onto the existing motor mounts.
<o></o>
Hope you all can make sense of what I am attempting to do and perhaps share some advise or tips….
<o></o>
Yes, it can be made to work, (most things can, some not so well) but its not for the faint of heart!
Have you read this, (and if not why not)?
https://www.ford-trucks.com/forums/6...-articles.html
Look at post # 12.
(these links below do not work, and I'm too lazy to post all of them, I wonder why these never said ford, dodge, etc. etc., you have to look at them all to find the one you want)
From the steering and suspension section –
( all 12 parts of our front suspension series) –
https://www.ford-trucks.com/article/i..._Part_One.html
https://www.ford-trucks.com/article/i..._Part_Two.html
https://www.ford-trucks.com/article/i...art_Three.html
https://www.ford-trucks.com/article/i...Part_Four.html
https://www.ford-trucks.com/article/i...Part_Five.html
https://www.ford-trucks.com/article/i..._Part_Six.html
https://www.ford-trucks.com/article/i...art_Seven.html
https://www.ford-trucks.com/article/i...art_Eight.html
https://www.ford-trucks.com/article/i...Part_Nine.html
https://www.ford-trucks.com/article/i..._Part_Ten.html
https://www.ford-trucks.com/article/i...rt_Eleven.html
https://www.ford-trucks.com/article/i...1953_F100.html
Go this link, it's about Crown Vic front clip transplants (not good, too wide) but it talks about other clips with links (?).
https://www.ford-trucks.com/forums/8...-1959-s-b.html
Picture # 1 and # 2 below;
And when everything else fails, (I think you need 25 posts),....... use the search feature until your eyes bleed. So post away.
Look at post # 12.
Hay All –
<o></o>
<o></o>
Look at post # 12.
Look at post # 12.
Hay Donald,
Thanks for the input – Welding is not an issue for me – pretty proficient with both Stick and Mig, 110 and 220 V The problem I have is in my HEAD – for years and years I’ve spend thousand of hours getting everything back to original form. So as a Purist it’s difficult to start hacking away…. seams sacrilegious if you can understand what I am saying. The grand kid is pushing for a street rod – says the others are just NOT COOL…In any case, I was able to cut away the front suspension from the T-Bird yesterday…but only after hours of devote prayer. If your familiar with the T-Bird front end - it’s an entire one piece clip – with these wing like extensions which are weld to the frame / rocker rails. So taking that off was a piece of cake, don’t even need to dismantle the front end, although I did. Hopefully today I will get to the 60 frame….. I’ll post some pics later today or tomorrow of my progress….Thanks for the advice…..nice set of wheels your driving and a great web site…..Thanks Again – I am located in the Northeast,
<o></o>
Hodge
<o></o>
Hodge
HkyswiM
12-26-2011 05:41 PM
pcctim
04-14-2009 11:45 AM
