$ of oil change service - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 10-03-2009, 05:50 PM
Gwilkrrs
Gwilkrrs is offline
Gwilkrrs is gaining momentum as a positive member of FTE.Gwilkrrs is gaining momentum as a positive member of FTE.
wow. nothing like the 7.3
68 for an air filter
12 for an oil filter
12 for the 5 gal jug of oil
and i havnt even been able to get a fuel filter yet.
wow 20k service is $$$$$$$$$$$$
wher is the best place to buy this stuff?
Old 10-03-2009, 07:55 PM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
oil from wally world. Filters and such from from ED. http://www.trademotion.com/partlocat...?siteid=214072
Old 10-04-2009, 09:26 AM
69cj's Avatar
69cj
69cj is online now
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Why are you changing the air filter at 20,000 miles?
Old 10-04-2009, 02:51 PM
freekyFX4
freekyFX4 is offline
freekyFX4 is starting off with a positive reputation.
Where do you get CJ4 oil for $12 for five gallons? I pay $19 a gallon for the Shell Rotella full synthetic 5w-40.
Old 10-04-2009, 04:50 PM
69cj's Avatar
69cj
69cj is online now
Where do you get any oil for $12 for 5 gal??
Old 10-04-2009, 06:45 PM
rmosso1
rmosso1 is offline
rmosso1 has a good reputation on FTE.rmosso1 has a good reputation on FTE.
Suggest you check your book. I do not believe that FORD reccomends using synthetic oli.
Old 10-04-2009, 07:12 PM
69cj's Avatar
69cj
69cj is online now
I haven't seen where Ford recommends dino or syn. Just API ratings and weight pertaining to temp. and normal or severe duty.
Old 10-06-2009, 10:26 AM
rock_doctor's Avatar
rock_doctor
rock_doctor is offline
rock_doctor is starting off with a positive reputation.
Oil (~$11 per gal) and filters (~$17) from walmart. Fuel filter have to come off the web or your local dealer. Most change the oil and filter every 5k miles, fuel filters every 15k and the air filter when ever the minder tells you to change it. That could be as much as 60k or more miles (depending on the environment). It is not the same type of filter the 7.3 used. It is a high capacity filter that can hold several pounds of dirt.
Old 10-07-2009, 01:40 PM
Gwilkrrs
Gwilkrrs is offline
11.55 for 5 gallons at wallmart. they didnt have any filters. advance had oil filters at 20 each and the air filter at crazy money, with no fuel filters.
for a 20k service it looks like oil/filter, and both fuel filters.
Old 10-07-2009, 01:55 PM
senix's Avatar
senix
senix is online now
be sure you use the motorcraft filters so they fit correctly.
Old 10-07-2009, 07:37 PM
69cj's Avatar
69cj
69cj is online now
I do believe u mean 11.55 for 5 qts. or you r running heating oil. And cheap heating oil at that.
Old 10-07-2009, 08:44 PM
caprang's Avatar
caprang
caprang is offline
caprang is gaining momentum as a positive member of FTE.
My manual shows synthetic 5W40 as a recommended or approved oil. Its one of the options on the chart and it covers all the temp ranges. It overlaps the 15W40 and the 10W30. Of course it says MOTORCRAFT 5W40 but it also says MOTORCRAFT for the 10W30 and 15W40 too.
RM2738
04-17-2013 07:57 PM
flexman
10-10-2010 11:11 PM
Thenewboss
6.2L V8
13
10-05-2010 05:16 PM
shade1965
02-28-2010 11:27 AM
FERacing66
Oil & Lubrication
03-01-2004 08:23 PM
Quick Reply: $ of oil change service
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
