Help Ford Vin and door sticker info
I need to find out the axle info ect, Im swaping the stuff into a bronco
Vin: 1FTHF26L6FKA7####
GVWR: 8600LB
GVR: F268
Axle: 73
Spring: 6K
[F0210, T0331]
Front axle (TTB 8 lug pattern)
354(triangle)E5TAS
(Triangle)610231-2
Rear axle I could only make out one number, and that was 60
The truck has a 7.5L 460.
Is the rear a Dana 60 and the front a Dana 50???
GVWR: 8600LB
GVR: F268
Axle: 73
Spring: 6K
[F0210, T0331]
354(triangle)E5TAS
(Triangle)610231-2
