Key FOB for 2000 F250
I know the GEM is different, but I think the VSM is stilling going to be similar to the later models. I believe to get into keyless programming mode, you turn the key on/off 3 times and press the door lock button. If you have keyless entry, then the door locks should cycle and be ready to accept your fobs.
Probably the easiest and most effective option would be to add a remote start/alarm. There are some really nice units available with cool features such as turbo timers, 2 way remotes, Tap sensors to unlock/disarm without keys/remote, ect.
On an XLT, it is a good chance it doesn't have keyless remote. Power locks were standard on the XLT, keyless remotes were not.
To test it, find or download your owners manual. Use the procedure for programming new key FOB's. If the locks don't respond when the manual says they should, then you don't have that option.
You can also get a build sheet for your truck from Ford. I believe the option was called Advanced Security System which included keyless entry.
I have a 1999 XLT and it came with the fobs. It does have a Ford factory add on "box" under the dash. The install and operating instructions were in the glove box when I bought the truck. You can tell the box was added into the factory harness, probably at the dealer. The fobs are factory also.
Bill's correct. The remote keyless entry system was a $170 option on the XLT per
2000 Ford F-250/350 Super Duty Options - Consumer Guide Automotive
Pop
Pop
anyway to get a picture of this?
