Bad noise at idle
Bad noise at idle
2000 F350 super duty,7.3, 205,000mi
Hi Guys, I haven't been around in a bit nor posted, Sorry. But I figure ask the pro's about this.
At Idle, Sounds like a real bad main bearing(just for comparison) Raise the idle(by peddle)200rpm, Gone? I also revered her up good to be sure it ain't a bearing.
I took the truck on a 300mi round trip now it's worse. much worse rattling sound.
The converter/flywheel bolts are tight
all pulley's seem tight on front of motor. Someone said possible Harmonic ballencer?
Someone else said possible bad converter in tranny?(Damm GM owners!!LOL) However the more I try to locate the noise, The more I am thinking back of motor
Thanks for any suggestions
Here we go again
Hello My Diesel Buddy's
Well, Not even 7000 Miles and the Flywheel is Toast AGAIN.
Musta been a toys are us flywheel
It's Rattling Real Bad and Bent.......AGAIN!!! The starter don't get on the teeth and I gotta get Godzilla Open end and turn the motor some to start.
My 2000 7.3 is stock, 212k miles
Me thinks I need a OEM or High performance Flywheel?
If they didn't use a new engine spacer and crankcase spacer, and they were damaged causing misalignment, than that is why the new flexplate is once again bent.
Rick_Fury
03-29-2019 01:39 AM
Zwalters
58
05-13-2017 06:25 AM
John12341234
1983 - 2012 Ranger & B-Series
03-30-2013 09:34 AM
