1994 F150 Body lift question
Old 04-11-2010, 08:17 PM
Ajc11892's Avatar
Ajc11892
Ajc11892 is offline
Hey i have a 1994 F150 with a 302ci and 4wd. i want to buy a 3 inch body lift to give me more clearance and to put bigger tires on. What im worried about is what else rather than the steering column that i have to worry about like the water pump or brake lines. Anyone have any pointers, or information i would need to know i would greatly appreciate your help. Thanks
Old 04-13-2010, 08:26 PM
ReAX's Avatar
ReAX
ReAX is offline
I used to use Performance Accessories kits just because of this. You will need to lower the radiator fan shroud, the parking brake cable bracket, and something else I'm forgetting. Then on occasion the shifters will need to be lengthened.
You'll spend a little more money, but you can get lifted coil springs from companies like trailmaster for the front and do blocks in the rear. There should be less of the tedious work involved though.
Old 04-17-2010, 11:35 AM
Ajc11892's Avatar
Ajc11892
Ajc11892 is offline
thanks hey
Old 05-29-2010, 02:09 AM
Muddy Truck's Avatar
Muddy Truck
Muddy Truck is offline
if your truck is a manual or you have a 4x4 stick, you will need extentions for those.
Old 06-14-2010, 11:34 PM
volksinthevalley's Avatar
volksinthevalley
volksinthevalley is offline
why not go for 5"?
Old 06-15-2010, 06:14 PM
ReAX's Avatar
ReAX
ReAX is offline
Who's making 5"? PA only used to do 2" and 3" kits. The closest I've seen to a 4" kit was a friend of mine used 4x4 post. It was ~4" when it was dry and 4.25" when the humidity was up.
09-05-2016 09:16 PM
CAredneck15
05-15-2016 11:37 PM
Mread22
03-13-2016 10:23 PM
xminnomarux
09-07-2015 02:06 AM
V AZARIAH V
Offroad & 4x4
09-20-2014 07:28 PM
Quick Reply: 1994 F150 Body lift question
