Anybody around here going? I didnt fare to well last time I tried it. My motor is stock and tired. It was mighty wet and sloppy, maybe I should try again.
I'll be there. Along with some former minions. I am hoping to have the Bronco going.. I had it running for about 10 minutes today before I lost fuel pressure!!
Hey do you know the website for them? I keep asking Karl and then forgetting before I get to the site. I need to check out their regulations to make sure I'll pass tech. Is there anything I should know about?? Do I need a helmet to run?
Yes you need a helmet. I had a old one but they didint check it for dates. I think you could be in the stock class, motor in stock location, axles in stock location.
I'm flat out of time to work on the Bronco, Karl has kindly offered to get it running for me if I drop it off at his house though, so hopefully I will be running it this weekend.. watch out stock A class!!
Are you going to run 4lo or 4hi? If I had more HP i would like to try 4hi for wheel speed. My motor could not pull 3rd gear in 4lo so Im scared of 4hi.
How did yall place, Did you blow through it? This is what I was doing haha, Its too close to hunting season to break my truck. I'll be back there next year.
I got 7th, not bad for finishing the truck just before we got there. Didn't have enough RTV on the intake manifold, just need to reseal it and it's good to go.
