Rear window swap 88ish to 85?
I stripped some parts from a newer truck years back ( Just before I had it crushed ) and want to swap my leaky sliding rear window in my 85 with the one piece from the newer 88ish. I cant remember what year it was exactly, but the panels behind the seats have the speakers and newer seat belts unlike the 80-86. The dash instrument panel, and radio bezel seem the same. I just need to know if the glass and the weather stripping will fit correctly?
Thanks
Thanks
on
The windows are interchangeable, 1973-1999 actually.
1973-1983: F-100
1973-1996: F-150/F-250
1997: F-250HD/F-350
1973-1999: F-600/F-900
Be aware however that the one piece rear window was updated in 1980. The 1973-1979 has thicker glass, and a different seal as a concequence. You can swap them 1973-1996, you just have to make sure the seal and window match or it won't seal correctly.
Also be aware that the factory slider was updated in 1982. 1973-1981 uses the same factory slider and seal. 1982-1996/7 uses the modern slider and different seal.
Part numbers for the appropriate seals for the apropriate windows upon request.
1973-1983: F-100
1997: F-250HD/F-350
on
Also the factory slider has drain holes at the bottom. They have a tendency to plug up.
Im not sure about the drain holes, but the little plastic clips that the glass slides on are destroyed and are impossible to open/close and the wind causes a whistling noise, and the leaking prob as you said the drain holes are clogged.. Its almost 25 years, and I have a free window so its time.
mark460
12-10-2010 01:43 PM
Talyn
12-01-2008 10:13 AM
