Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
New battery time for me, before winter freezes the ones I have
Old 09-23-2009, 09:23 PM
Visseroth's Avatar
Visseroth
Visseroth is offline
Visseroth has a good reputation on FTE.Visseroth has a good reputation on FTE.
So winter is getting close and it can get down into the -#'s here for a few weeks out of the winter and my batteries are talking to me by caroding the battery terminals pretty badly. I had to clean them last week because of all the junk growing on the terminals and I'm sure I need to battery terminals as the one that links to the driver's side battery is swelling, corroding and starting to come apart where the two batteries come together.
So my question is what do you guys recommend for batteries? Obviously the more cranking amps the better but what brand or brands and about how many cranking amps per battery?
Also does anyone know where I can buy replacement battery cables since I will be replacing these as soon as I can.
Old 09-23-2009, 09:27 PM
conger's Avatar
conger
conger is offline
conger is gaining momentum as a positive member of FTE.conger is gaining momentum as a positive member of FTE.
Just put two new ones in from Wally last week. I was just thinking the same thing. Weather's been awesome lately, but reality check and the big freeze is coming soon.
Old 09-23-2009, 09:29 PM
fifthwheel01
fifthwheel01 is offline
fifthwheel01 is starting off with a positive reputation.
check out this thread, it has some good info.
https://www.ford-trucks.com/forums/8...re-to-buy.html
Old 09-23-2009, 10:04 PM
Visseroth's Avatar
Visseroth
Not a bad idea. Hopefully I have enough room to cut the cables back a bit and get the terminals replaced. I'll be sure to goop them up with something that will keep them from oxidizing and getting nasty.
So I'll subscribe to it as well but I still need to replace the batteries. Suggestions?
Old 09-23-2009, 10:15 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
I have been running Wally batts for a few years now.
Old 09-23-2009, 10:23 PM
Visseroth's Avatar
Visseroth
Wally mart? I've heard bad things, maybe that was just rumors.
Old 09-23-2009, 10:32 PM
Tenn01PSD350
I have heard bad things too, but I have a warranty and they are everywhere. There is 5 superstores within 15 miles of my house. What can I say? Besides, I got an employee discount when I bought them. I was working off duty security for them back then.
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
There's a reason your terminals are corroding your cable ends. Usually it's overcharging that forces some of the acidic electrolyte out, causing the corrosion.
Look for other signs of OVER-charging. Loss of battery acid? Need to add distilled water often?
Pop
Old 09-24-2009, 12:08 AM
Visseroth's Avatar
Visseroth
Well about 2 or 3 months ago I added some water to them but it wasn't distilled water and they weren't coroding before that so I'm betting it's because i used tap water which would explain why they are "over charging" too.
Old 09-24-2009, 12:27 AM
binuya's Avatar
binuya
binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Costco batteries here. 3 yr replacement, 850cca, $75.00 ea. last April.
Old 09-24-2009, 12:40 AM
Tenn01PSD350
Yeah, whatever you get, make sure it is at least 850CCA
Old 09-24-2009, 01:46 AM
Visseroth's Avatar
Visseroth
ahh, I see Napa has some 750CCA's but I'll have to check out Cosco this weekend and see what they have.
Old 09-24-2009, 02:09 AM
Visseroth's Avatar
Visseroth
Well found a 850, here's what I'm looking at, 850 CCA 1000 @ 80F and 150 minutes @ 25A
which all doubles in our trucks
Old 09-24-2009, 02:30 AM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.
Vis, i was recently in the same boat as u before i deployed. I went to Autozone i believe and got the Duralast Golds. less than $100 a piece and all the CCA u will need. i cant remember the CCA, but they are good batteries. and the Warranty on them is 3 years, and after that prorated i believe. check em out.
Old 09-24-2009, 05:37 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
When you install your new batteries use Noalox on the terminals, it is electrically conductive so that you can put it on the terminal then put the clamp over it. You can buy it at any electrical supply house or HD or Lowes. It is made by Ideal . I have used it for years with great results.
Quick Reply: New battery time for me, before winter freezes the ones I have
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
