2008 - F450 - 6.4 - Overheating - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-07-2018, 12:58 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
Originally Posted by JBW11 View Post
I am having the same problem with my F-350 6.4L DRW. I just had the timing plate, oil pump, and water pump replaced because I had a small hole in the timing plate that coolant was shooting out of. I drove about 500 miles over the last day pulling my RV from Missouri to New Mexico when it started over heating. The terrain was hilly but not nearly as bad as it was a week ago when I was driving from NC into TN. My check engine light (wrench) came on and my coolant temp gauge immediately shot from "Normal" range to "Hot". I immediately pulled over and shut it off. I immediately turned the key on and my temp gauge was back to "Normal". I was in the middle of BFE in New Mexico so I had to get to the closest town. It happened four more times. My coolant is at the "Cold Fill Line" and it isn't leaking anything. Any ideas? I plan to drive it into the Ford dealer that is 3.9 miles away tomorrow. I need to get to CA quick.
Do you have a new 16 psi coolant cap ?6.4 needs 16 psi in the coolant system else the coolant will boil.AND , do not drive it....get it towed. If you have a cooling problem and you operate the 6.4 while itís over heating ....you could blow head gasket and or crack the heads / block.DITTO on putting a temp gun on it ....Is there more to the story??? ( new tuner running race tune , and DPF is still installed, etc)Whatís your mileage like right now. Clogged cat/ dpf will elevator temps quick.Again, do not drive an over heater ng 6.4, the engine is not forgiving.
Teamtiger21
03-22-2018 10:03 AM
mel105hunting
07-24-2017 03:35 PM
Pikachu
12-26-2016 08:26 AM
CKetchum
09-09-2016 09:06 PM
6.4_Stroker
18
02-17-2016 04:32 PM
Quick Reply: 2008 - F450 - 6.4 - Overheating
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
