Hydroboost conversion...
#51
I did my conversion this past weekend, got the setup from 89ford73. Nice to have a consistent pedal but need a little extra leg pressure then with the vacuum assist set up. The only problem I had is my 96 master cylinder had an ABS sensor that plugged into the wire harness and the hydroboost that I had gotton didn't have any ABS on it, not sure if later years do and not sure what year my hydroboost is from. Anyways I unscrewed the sensor from the vacuum master cylinder and just plugged it into the harness and the ABS light went out and so far has been out.
Should the effort to push the brake pedal with hydroboost be the same as with the vacuum assist?
Yes, the pedal feels harder to press than the vac brakes. You'll get used to it.
#57
The master that came on the hydroboost trucks has a larger bore I believe and I've heard of people having issues with too much pressure for our drum brakes. Not 100% sure on the validity of that though. I've got the larger master in a box so that wen I go to disk rear brakes, I can swap it over.
See that "nipple" that is directly below the front brake line... it faces down and to the inside of the motor compartment, towards the exhaust manifold. That's where the hb master cylinders have that ABS sensor mounted. Mounts down and to the inside instead of straight on top like our OBS has. Check and see if there is a plug in there. If so, just remove it and install the sensor. If not, then not sure what to tell you. But that's where it's supposed to mount on the larger master cylinder.
#58
on
Thanks Ryan. I actually did notice that in the picture, not sure why I didn't see it when I was installing it. I'll check it out. Right now with the sensor plugged in the light is staying off.
My rear brakes do lock up first but they did that with the correct vacuum master cylinder. May just put in a manual proportionimg valve.
Do you have any pedal play? I mean when I push the pedal there is no free travel, at least not very much. Should there be? If so how much?
#59
Does your cruise work? I know if that sensor goes bad it won't set the abs light but the.cruise doesn't work. As for them grabbing, it my be you rabs valve or could mean that your park brakes are still slightly engaged, or they just need adjusted. They are supposed to self adjust but don't always do so. Try backing up quickly and jamming on the brakes to see if that helps.
As for pedal, its pretty much instant. Takes more pressure to apply than before too.
Gotta catch this flight. Will check back later.
#60
